Author Topic: UV prefinished Plywood for arcade cabinet  (Read 1481 times)
Bloodta
  • Last login:March 29, 2025, 09:34:13 am
« on: April 15, 2024, 02:46:51 pm »
Has anyone used UV prefinished plywood to build an arcade cabinet? How does vinyl do on it?
RandyT
  • Last login:July 25, 2025, 02:17:35 pm
    • GroovyGameGear.com
Re: UV prefinished Plywood for arcade cabinet
« Reply #1 on: April 19, 2024, 09:51:26 am »
I haven't used it, but I would expect vinyl to stick to it like iron.  So long as the finish isn't leeching any oils (which it shouldn't be...I assume that the UV moniker is an indicator of a UV cured resin soaked into the outer layer) then that smooth and non-porous surface would be ideal.
If you aren't looking for that woodgrain look around the vinyl it might not have as much value, considering the extra cost.  But if you are thinking a large decal on wood-grain or a full wrap, it would probably be the best wood-based foundation for one available.  Definitely consider using the wet application method if you go this route.
Also, given the hard outer layer, make sure your machining process is compatible, to avoid edge chipping and the like.  It may or may not be as hard and fragile as melamine, but it's worth looking into that aspect before deciding.
Bloodta
« Reply #2 on: April 21, 2024, 04:46:16 pm »
Awesome, thanks for the reply. I’m hoping that it cuts down on the prep.
