Author Topic: LEDBlinky error (SAPI Parameter)  (Read 1635 times)
SBaron
  • Last login:January 28, 2025, 06:52:25 pm
« on: February 27, 2024, 08:11:54 am »
Hi,
First post so plz be gentle as I did search but did not find anything and I would bet this has been covered somewhere at some point.  So, a link is also welcomed.
Trying to setup LEDBlinky under LanchBox.  Figured out I had to install LEDBlinky outside of the plugins folder (LaunchBox/LEDBlinky) or it would cause LB not to load with an error.  Now it loads.  When I exit LB the log file from LEDBlinky showed I needed to place the colors.ini and controls.ini files in the plugins folder (plugins/LEDBlinky).  So did that.  Now if I exit LB LEDBlinky shows that I have 1 last error:  Unable to set SAPI parameters. OLE error 80045039  Any ideas/suggestions?
TIA
