I would like to add more buttons without losing the aracade look and feel.
OK.
How many buttons and what functions do they perform?
- Check
every game you intend to play.
Do you need to use them during gameplay? This can influence size/spacing/color/mounting/reinforcement choices.
Do you need LED buttons with vinyl stickers/printed inserts so they will be easier to read because of the lighting around the button box location?
We can't give you the best advice unless you tell us
exactly what you want/need and how you intend to use them.
The "6P" principle applies here -- Proper Prior Planning Prevents Poor Performance.
There is a 5mm gap where the controlboard is overlapping the edge. So i was thinking why not have some kind of cover and run the wires under it.
Sounds like a good choice might be a 3d printed button box with a 5mm lip that goes into the gap and hooks under the metal panel so it doesn't lift up.
- Given that the gap is 5mm wide, you should have no problem feeding the wires through to the encoder inside the main control panel.
- When printing the part, turn it so the right or left side of the box is down on the print bed. This will give you the best strength for the lip. Printing it face-down is the second best option. DO NOT print it top-down since that would give it the weakest lip.
- Design the box with a removable back panel for easy maintenance. Heat-set threaded inserts would be perfect for this application, but a snap-in back would work, too.
Are there arcade-like buttons that can be mounted flat in 5mm acryl? Maybe any other ideas?
Lots of options for this. Best choice depends on the details mentioned above.
I will probably rework the coin return buttons to coin/start buttons
Adding coin switches to the coin return buttons makes sense, but it seems like start buttons should go on the button box.
