Author Topic: HTTPS mode  (Read 52384 times)
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 23, 2026, 07:55:20 am
HTTPS mode
« on: January 21, 2024, 03:01:35 pm »
Please visit the site using https:// instead of http:// and let me know if anything's broken.
--- saint
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
  • Last login:Today at 12:53:52 am
Re: HTTPS mode
« Reply #1 on: January 21, 2024, 06:17:46 pm »
There are some parts of this thread page that are not yet secure -- probably either your profile image, the icons, or other images on the page are linking to an http server.
- I get the same "not secure" indication when I check your profile page and a new user's profile page.
[EDIT: Avatars are currently being pulled from the http server even though they are already available on the https server.  The images in my sig are coming from the http wiki server.]
PM sent to test if that system is working.
- The PM sending page shows not secure.
[EDIT: Awaiting reply/confirmation that PMs are working and secure.]
Email sent via your profile link to test if that system is working.
- The email sending page shows secure.
[EDIT: Email reply received so that system looks good.]
Wiki link at top of forum pages points to https://wiki.arcadecontrols.com/ which redirects to https://wiki.arcadecontrols.com/arcade.htm and shows the front page instead of the wiki.
- Wiki still available on http, but pages 404 when you try the URL with https.
[EDIT: Wiki is working in https.  Link at top of forum pages is https, but now it redirects to the non-secure http://wiki.arcadecontrols.com/index.php/Main_Page]
File Repository link at top of forum pages points to https://files.arcadecontrols.com/ which redirects to https://files.arcadecontrols.com/arcade.htm and shows the front page instead of the file repository.
- File repository still available on http, but pages 404 when you try the URL with https.
[EDIT: Only File Repository things left to fix are the two links mentioned in reply #9.]
Front page (http://arcadecontrols.com/arcade.htm)
- "Submit news" button link (top left) is still http.
- "Msg Boards" button link (left) is still http.
- "Chat Room" button link (left) is still http and returns a 404 message.
- "Wiki" button link (left) is still http and link does not work because it points to "newwiki" instead of "wiki" or "oldwiki".
« Last Edit: February 16, 2024, 04:13:42 pm by PL1 »
saint
Re: HTTPS mode
« Reply #2 on: January 21, 2024, 08:22:53 pm »
Thanks, will put on the fix list :)
--- John St.Clair
     Project Arcade 2!
Re: HTTPS mode
« Reply #3 on: January 31, 2024, 03:55:04 am »
Several more things to add to the fix list:
Index page - https://forum.arcadecontrols.com/index.php
- Under the "File Repository" forum link, the text "Discussion about the File Repository" links to the non-secure File Repository page.  Changing the URL to https redirects to the front page as mentioned earlier.
[EDIT: Redirection fixed.  Link still needs changed to https as mentioned below in reply #9]
- Under the "controls.dat" forum link, the text "controls.dat and related projects" links to the non-secure http://controls.arcadecontrols.com/ page.  Changing the URL to https redirects to the front page.
[EDIT: Redirection and link fixed.]
- Under the "Moderator's Forum" link, the text "Please see Moderator's Guidelines." links to the non-secure page.  Secure page is good.
[EDIT: Link fixed.]
Controls.dat forum - https://forum.arcadecontrols.com/index.php/board,45.0.html
- Above the page numbers, the text "controls.dat and related projects" links to the non-secure http://controls.arcadecontrols.com/ page.  Changing the URL to https redirects to the front page.
Moderator's forum
- Above the page numbers, the text "Please see Moderator's Guidelines." links to the non-secure page.  Secure page is good.
[EDIT: Link fixed.]
« Last Edit: February 16, 2024, 04:07:07 pm by PL1 »
meyer980
  • Last login:January 26, 2026, 08:20:18 pm
  • Building fun things for fun
    • sergiostuff.com/2020/04/15/felix-son-arcade-game/
    • Sergio Stuff
Re: HTTPS mode
« Reply #4 on: February 03, 2024, 10:01:08 pm »
It seems like, at least for me, the Dragon King website only works when not using https.
http://dragonking.arcadecontrols.com/static.php?page=AboutIFIFJ
that works
https://dragonking.arcadecontrols.com/static.php?page=AboutIFIFJ
that doesn't
The problem is Google or Chrome is sometimes trying to force the https so it seems like the site doesn't work.
Re: HTTPS mode
« Reply #5 on: February 03, 2024, 11:23:26 pm »
Pages like UncleT's and the Slagcoin mirror also don't work with https.
http://unclet.arcadecontrols.com/index.html
http://mirrors.arcadecontrols.com/www.slagcoin.com/index.html
[EDIT: Both sites now working in https.]
« Last Edit: February 16, 2024, 04:02:31 pm by PL1 »
saint
Re: HTTPS mode
« Reply #6 on: February 16, 2024, 01:57:31 pm »
--- Fixed, I think :)
--- Fixed
--- Fixed
--- Fixed
Moderator's forum
---- I seem to be blind and can't find this one.
Thank you Scott :)
--- John St.Clair
     Project Arcade 2!
saint
Re: HTTPS mode
« Reply #7 on: February 16, 2024, 01:58:25 pm »
These should be fixed now.
--- John St.Clair
     Project Arcade 2!
saint
Re: HTTPS mode
« Reply #8 on: February 16, 2024, 01:58:52 pm »
that works
that doesn't
These should be fixed now - thanks :)
--- John St.Clair
     Project Arcade 2!
Re: HTTPS mode
« Reply #9 on: February 16, 2024, 03:04:45 pm »
Redirect is fixed.
File Repository page and downloads working in https.
- Don't have a login to test uploads/logins.
The only File Repository-related things that need fixed are these two links that are still http instead of https.
File Repository Sub-Forum - https://forum.arcadecontrols.com/index.php/board,44.0.html
Moderator's forum
It's fixed.   :cheers:
  • Last login:Yesterday at 08:00:13 pm
Re: HTTPS mode
« Reply #10 on: February 16, 2024, 08:32:22 pm »
I used to work a gig that banned www.arcadecontrols.com but forum.arcadecontrols.com wasn’t on their filter.  It was amusing.
saint
Re: HTTPS mode
« Reply #11 on: February 17, 2024, 11:52:46 am »
Heh. Same actually. I forget which filtering service we were subscribing to at the time but I was bemused.
--- John St.Clair
     Project Arcade 2!
Re: HTTPS mode
« Reply #12 on: February 17, 2024, 12:50:43 pm »
Barracuda for me.
 :dunno
saint
Re: HTTPS mode
« Reply #13 on: February 17, 2024, 04:39:34 pm »
Bingo, that was the one we were using also.
--- John St.Clair
     Project Arcade 2!
Re: HTTPS mode
« Reply #14 on: July 01, 2024, 11:04:15 pm »
The Rules link at the top of the page throws a "500 Internal Server Error" because it points to https://new.arcadecontrols.com/arcade_message_rules.html instead of https://arcadecontrols.com/arcade_message_rules.html.
saint
Re: HTTPS mode
« Reply #15 on: August 17, 2024, 07:00:28 pm »
Fixed, thanks :)
--- John St.Clair
     Project Arcade 2!
