Author Topic: Dreamcast in a cabinet..  (Read 3322 times)
jlampc
  • Last login:February 02, 2022, 07:33:58 am
  • I am not an animal !!! I am a gamer
« on: March 05, 2004, 02:02:48 am »
I have a new cabinet and I would like to try to put a dreamcast in it. I have about 200 games for it and would like  to figure a way to use it. The Cab has a medium resolution Arcade monitor connected to a jamma harness..I am pretty lost. I've been looking for an RGB part for the Dreamcast and have been unsuccessful. If anyone has experience with this lemme know!!!
ThanX :D
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
Re:Dreamcast in a cabinet..
« Reply #1 on: March 05, 2004, 10:47:41 am »
this needs to be in the console section.
but to answer your question, it can be done using a dreamcast vga box. you remove a certain pin to force to 15khz or whatever. search around i have seen people talking about this in the console forum before
good luck 8)
Stingray
« Reply #2 on: March 05, 2004, 11:07:25 am »
Seems to me that it would be MUCH easier to just sell the arcade monitor and put a TV in the cab.
-S
gnateye
    • natty's arcade
« Reply #3 on: March 05, 2004, 11:26:04 am »
which brings us back to the super gun. i plan to add one to my dreamcast cab (which has a 24" svid tv) so i can multi use that cab a little better.
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #4 on: March 05, 2004, 12:37:49 pm »
I had been planning to do this as well, since there are a lot of other console emulators that run on the Dreamcast.  Then I just decided to run them all from the PC.
I would do what Stingray suggested and just use a regular TV instead of an arcade monitor if you can't find the parts you need.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #5 on: March 05, 2004, 04:45:11 pm »
Is everyone smoking crack in this thread? :)
First of all, the Dreamcast to arcade monitor hack is very simple, and fully documented in the byoac console faq:
http://www.arcadecontrols.com/arcade_consoles.shtml
All you do is snip one wire.
Second, since your cabinet uses a Med Res monitor (24khz), you will  find that the dreamcast can NOT output that frequency (only NTSC-15khz, and VGA 31khz).   Sorry but you are out of luck.
Although in this particular case swapping the monitor out with a TV is a plausabile option, its only because this is a medium res monitor.  But I'd take a std res arcade monitor over a tv with s-vid anyday of the week!  So probably swapping the med res monitor out for a std res monitor is a better option IMHO (otherwise you have to kludge a way to securley mount the TV in the cab).
« Last Edit: March 05, 2004, 04:48:56 pm by Dave_K. »
jlampc
« Reply #6 on: March 17, 2004, 12:46:33 am »
good news. my monitor is switchable to 15khz... ;D
I am looking over the link for the VGA hack as we speak. My final plan is touse the dramcas and a pc for mame. My issue is how toswitch back and forth....I'm also stilltrying to figure out what the different wires do...sigh....
thanx for the help
