Author Topic: U360 Ultrastik bat/oval top 9mm vs 12mm shaft  (Read 1613 times)
flynnb
  • Last login:February 13, 2025, 10:32:45 pm
« on: November 26, 2023, 09:49:57 am »
Anyone know if it makes a difference if I use a 9mm diameter shaft vs 12mm. T-Moulding (aka arcaderenovations) website sell a 9mm variant with their bat/oval tops. I can save some $ on shipping etc since eventually I will be ordering a total of 4.
Per the sebsite: We only sell the 9mm diameter shaft and include an M10-1.5 to M6-1.0 thread adapter for the Sanwa top. We do not stock the 12mm diameter joystick that Ultimarc uses for their bat tops.
haynor666
  • Last login:July 25, 2025, 04:09:52 pm
  • retro maniac
Re: U360 Ultrastik bat/oval top 9mm vs 12mm shaft
« Reply #1 on: December 23, 2023, 08:07:37 am »
I prefer shorter shaft since I have joystick mounted in metal (thin) rather than wood (thick). It's far better this way especially for shumps.
As for thickness it does not matter for me judging from many sticks I have in the past.
« Last Edit: December 23, 2023, 08:11:19 am by haynor666 »
GeoMan
  • Last login:Yesterday at 11:09:46 am
« Reply #2 on: December 25, 2023, 03:35:46 pm »
What is really important is the length of the Ultrastick shaft. If you mount it on wood you definitely need the long one.
I have mounted Ultrasticks on both metal and wood.
