Author Topic: MAMEHooker Script Options  (Read 2495 times)
baritonomarchetto
  • Last login:October 12, 2025, 10:20:50 am
« on: November 19, 2023, 10:53:40 am »
Hello everybody, I am toying with a SNK positional gun a friend of mine gave me.
I am testing the kicker with some games.
As most of you already know, there are games like Operation Thunderbolt outputting a state HIGH message when keeping the trigger pressed, not a pulsating HI/LO state change. To face this, I wrote a simple MAMEHooker script that should loop forever when the trigger is pressed to alternate the kicker state.
This is the script I wrote (othunder.mhs)
Code: [Select]
cmw 4 1., cmw 4 %Player1_Recoil_Piston%, cmw 4 x
wat 50
cmw 4 1., cmw 4 0, cmw 4 x
Now, as far as I know if I call this script from othunder.ini with the command "lfs" (loop from the script?) the script should loop forever:
Code: [Select]
Player1_Recoil_Piston=lfs othunder 0 %s%
Unfortunately it does not. It makes nothing. If instead I use read from the script (rfs) function, it works (only once, as expected)
Code: [Select]
Player1_Recoil_Piston=rfs othunder 0 %s%
Could someone confirm the function lfs actually works or eventually point out what I am doing wrong?
Thanks! :)
« Last Edit: November 19, 2023, 10:55:37 am by baritonomarchetto »
baritonomarchetto
Re: MAMEHooker Script Options
« Reply #1 on: November 21, 2023, 12:53:24 am »
Made some further testings yesterday. Looks like the "lfs" command doesn't like a waiting time equal to zero. Rising it to "20" fixed the issue :)
