Author Topic: Alien extermination guns - ali express - UK - trusted sellers and tips  (Read 28027 times)
ant2
  • Last login:June 02, 2024, 07:05:47 am
Hi all,
I am really interested in mimicking this set up:
https://youtu.be/Vl34l1122RA?si=kuZFu8LKZgtVYB7y
Those guns look a  lot of fun!
1.)
Have any of you purchased these guns, if so which seller do you recommend?
I found this link on a retro ralph clip- https://bit.ly/2YG5pkw
Any one used them, is there a cheaper supplier?
2.) What power adapter would you recommend, the one retroralph recommends I can't source from the uk - https://amzn.to/3jaQiZQ
3.) Are there any good documents videos for getting this wiresdup/configured. I saw a video from brad that looks helpful for once the wiring is done and having this integrate with mamehooker - https://youtu.be/Vl34l1122RA?si=NV7ml4Os9yIAswrw
5.) Has any one integrated this in to a standard cabinet, looking for ideas. Was wondering if I built the guns in to a shelf that I could atrach to the front of the cabinet, sitting infront of the control panel, that could be disconnected,
I did try and search through the forum and couldn't find any relevant posts.
esoteric_rt
  • Last login:July 16, 2024, 08:04:33 pm
Re: Alien extermination guns - ali express - UK - trusted sellers and tips
« Reply #1 on: November 07, 2023, 07:57:22 pm »
I'm going through this process myself at the moment.....
I ordered 2 of the guns off aliexpress from this seller:
https://www.aliexpress.com/item/32856457183.html?spm=a2g0o.order_list.order_list_main.10.6d221802RUCJY8
Those were the cheapest I could find because the shipping cost is so high to New Zealand. The seller has sent the items in 2 packages. The first package arrived yesterday. I thought they simply would have sent 1 gun in each package but no, only the gun shells and screws arrived in the first package. Obviously the heavier parts are in the second package which was sent via a cheaper postage option. I hope they are all there when they arrive.
I've also watched the Retro Ralph and Brad videos on Youtube. That's about all the info there is on wiring these up. Its going to be a long process of trial and error to get the recoil function working in game.
I can add some more info here once the other parts arrive and I've had a chance to work with them.
MrThunderwing
  • Last login:Yesterday at 07:15:09 am
  • As I pass, do I give you the ass or the crotch?
« Reply #2 on: November 08, 2023, 08:49:59 am »
Well, colour me interested in future updates to this topic. Look forward to seeing how this progresses!
ant2
« Reply #3 on: November 08, 2023, 03:26:38 pm »
I made some progress, there is little information about these guns and people using them and I am going to write up some information that took me (days + weeks) to get answers.
1.) I ended up sourcing 1X https://www.aliexpress.com/item/4001167723575.html?spm=a2g0o.order_detail.order_detail_item.3.5b77f19c62DQOt
This gun works fine, no issues with seller, my gun game complete. I have ordered another one
2.) Ensure you order a gun with "USB" output, other than that the product seems the same.
3.) I found no information of how many amps is required to run the guns. Bandicoot was the only member here whom I messaged (who has the guns) and answered some of my questions. He suggested a 6amp supply for the 24v recoil, others seemed to be using 5amps, but I did read someone whom stated they were having issues with a 5amp supply with 2 guns.
The USB is plugnplay. It required no drivers and powers the rear LED output of the ammo count.
 The red wire is for the recoil, this requires a 24V power supply. - I used https://www.ledkia.com/uk/buy-indoor-led-strip-power-supply-adaptors/72595-180w-24v-universal-power-supply.html
 The yellow is for the LED's and required a 12v supply - https://www.ledkia.com/uk/buy-indoor-led-strip-power-supply-adaptors/189-12v-60w-universal-power-supply.html
The LED's are for the grenade front left button and the flame thrower. I saw others had an LED output from the gun strip, but on Aliens (the only one I have tested so far) mine does not illuminate.
The black is the neutral/ground. - I know little about electronics but because I was running 2 PSU's and I had only one ground output that is sharing it my dad suggested connecting the 2 power supply neutrals together, bandicoot confirmed the same, this works without issue.
4.) After plugging in the gun test it with Alien extermination. The gun was made for this game and it will detect it natively at startup (do not run it via teknoparrot). Ensure you calibrate the gun in windows first to all directions, then calibrate the gun within game (press 5) to get full range of motion.
The recoil works natively in this game (good game to start with)
The recoil is pretty strong (and fun). I haven't done any further testing as I want to get the guns in a pedestal, as it's annoying having 1000's of wires and the guns resting off bolt threads resting on a desk and having to keep tidying it away :)
5.) I am now building a pedestal to house these huge guns. The idea being is my kids and I will use it off a TV and I will bring down my PC downstairs (until I upgrade my 15 year old windows XP arcade cabinet) then I will wheel it up to that.
The pedestal will have the 2x guns, the internals will be housed in a wooden box and covered with leather. I have finally finished the boxes, which took quite a bit of fiddling to make sure I had the correct heights and didn't foul the internals.
It will have a joystick running off a zero delay encoder and around 6 buttons. I have built a hidden shelf which will house all the amps, the bolting of the guns, joysticks, buttons etc
They do sell the plastic on aliexpress to house the guns, it's about £110, which seems a lot for plastic. If someone had a 3d printer then that would be a good option
6.) The software is a bit of a pain. What I have done here is use the "biohazard" gun build, then removing all but the rail shooters. - Nearly complete
We then need to pass the teknoparrot, sega model etc via demulshooter so we can get the guns to work. I need to create individual bat files for each of these to do this.
We can then use mamehooker to grab the recoil outputs and use them to output the recoil on the gun. This will require many mamehooker configs.
I haven't done the above yet, but I know people who have got this working with the Wii games too. 6 has already consumed a lot of time looking at "how" this can be done.
mamehooker and demulshooter need to run in administrator mode or you won't see outputs (took a while to figure this out)
You also need to enable the "outputs" in demulshooter so mamehooker can see them.
Will update this thread with more tricks/tips as I get through this. Very time consuming
Attached pictures of my shelf I had on my phone (in progress) and gun enclosures, the melamine top is in the back of the picture and will be placed on top of that shelf.
I have painted the gun encasements black, but they will be covered in leather, it was just to seal the wood.
The fronts of that shelf will have P1/P2 + P1/P2 credit buttons, the rest of the buttons + joystick will be on that melamine piece at the top
<a href="https://ibb.co/QmyMb2x"><img src="https://i.ibb.co/3hgcrDP/20231108-133054.jpg" alt="20231108-133054" border="0"></a>
<a href="https://ibb.co/DVxDhKP"><img src="https://i.ibb.co/f1hYf0V/20231108-164952.jpg" alt="20231108-164952" border="0"></a>
ant2
« Reply #4 on: November 13, 2023, 03:10:05 pm »
Update, finishes the pedestal. Still waiting on my second gun so there is a hole where this is mounted.
https://ibb.co/DGJjSPJ
After that's mounted screws going to be painted and that's complete. Will take some better pictures once it's complete.
The pedestal has a metal frame allowing height to be adjusted. the front panel comes off so the gun connections and joysick controller can be maintained without unscrewing the whole top.
The front has credit P1, P1 start, credit P2, P2 start.
The buttons on for the front end, joystick, button1= enter/select game. button 2=back in menu. Button 3=exit game.
Otherwise the middle button is used for "service mode"
Software, wow, i've spent over 40 hours trying to get everything working. I forgot how much of a PITA to get this stuff done and how everything breaks in weird ways.
Lessons learnt, ensure demulshooter,mamehooker are started in admin mode when you are first hooking.
supermodel and model2 also had issues when first hooking if not in admin mode.
Mamehooker needs this to be installed or you will get weird issues when hooking or trying to edit the current ini file - https://www.majorgeeks.com/content/page/richtx32_ocx.html
Windows10 assigns USB devices upon plug in, there appears to be no way in pinning this. Ensure when you are configuring you have plugged them in the same order, or waste 5+ hours like me going back to old games and wondering why they are now no longer working.
This is extremly annoying with alien extermination as I can find no way of getting my gun1 to recoil anymore and it's set to gun2, no matter if I switch usb inputs. I worked out this if you use demulshooter to call alien extermination, this fixes this issue.
Perform keybinds -> joysticks with joy2key, this seems to be the most reliable way.
Some games do not recoil right even though the output is hooked (transformers) and some others, this can be hacked around using keystates and joy2key sending 8 presses a second.
mame needs to have dsp output set to win in the global config, also run mame in admin mode when first hooking.
teknoparrot needs to have all gun outputs set to none and unbound or it demulshooter does not pass correctly.
supermodel does not have native recoil outputs, but can use keystates using the joy2key as mentioned above
Nintendo wii doesn't work in mamehooker so we can't get any rumble -> recoil etc here.
I have got mame, model2,supermodel and 4 teknoparrot games working so far
Let's go island 3d gets stuck asking for the dongle when using the first map under easy mode, I have found that resetting the game using (c) fixes this. I bound my pedestal middle button to that to work round that.
If you are using the biohazard build, some of the existing exe's are using a local demulshooter inside the rom dir, ensure you modify those ahks to your own demulshooter exe instead of wasting hours like me working out why the guns don't work.
Ensure you "calibrate" the guns in any game you set up via the set up menu.
Issues thus far not yet resolved:
Teknoparrot. I cannot get haunted museum 1 + 2 to work with the guns. I can see it hook to demulshooter and see outputs in mamehooker but the guns do not work, I can't even see the axis change in the "calibration" set up menu when moving the guns. If any one figures this out let me know.
EAPD I cannot get to hook, I think this may be an issue with the name of the binary that demulshooter is expecting - http://forum.arcadecontrols.com/index.php/topic,168052.0.html
RPCS3: Tried to get deadstorm pirates to work, I got it to load a few times but now I get a black screen and it fries my computer with interrupts that starts hanging up the machine. I tried rebuilding the cache several times and still no dice. Given up on this.
Have about another 10-15 teknoparrot games to go and then I think I will leave it there and do a video.
Once I finish this up, I am happy to share all the ahk scripts, configuration files and mame hooker ini files, to save someone else the 50 hours.
bandicoot
  • Last login:December 18, 2025, 12:30:46 pm
« Reply #5 on: November 14, 2023, 11:37:23 am »
for RCPS3 , you need to launch demulshooter after game is load
Look on the demushooter
https://github.com/argonlefou/DemulShooter/wiki/System-357
best way is an ahk with a sleep after RCPS3 is launch ( time is depending of your computer )
ant2
« Reply #6 on: November 18, 2023, 05:54:20 am »
Still waiting on my second gun and alien extermination poster.
Front end now complete.
All games linked to guns with recoil (except wii)
https://youtu.be/b-05KTxAppE?si=lOxDkCxx1wSy4sHl
https://youtu.be/yAp-_LPIXc8?si=otxQzg-8dXQ_3__O
esoteric_rt
« Reply #7 on: November 26, 2023, 04:22:58 pm »
Great work, you move fast!
The rest of my gun parts arrived. Sadly the bolts and plates were bent but I managed to get them looking OK and assembled the guns. The hardest part was working out how the spring sat in the gun for the trigger.
Completed a quick test yesterday, using Aliens Extermination first of course. I got several other games running through Teknoparrot, including House of the Dead 4, which works pretty well with a positional gun once configured;
If you are able to share your config files once ready, it would be a massive help for me!
I will start building a cabinet in 3-4 weeks. It will likely be a full integrated unit and not a pedestal.
ant2
« Reply #8 on: November 28, 2023, 07:12:00 am »
wow, nice arcade room. Good job on putting those guns together, I am quite glad mine came complete.
I am still waiting for my second gun, been 3 weeks so far. My first one came in just over a week.
Attaching the mamehooker files , joy2key and rom AHK scripts here. These are what took an age. Everything hooks via demulshooter.
Really wish others had shared there configurations as it takes so long. PM me if there is anything else you need
For some reason mamehooker switches between creating/reading the "mame" directory and "supermodel" directory for me. i.e teknoparrot may start saving files in the "supermodel" directory.
I just copied the files to both directories to get round that issue.
For the mamehooker configurations where you see "keystates":
RefreshTime=25
Y=nll |ghd 1 &H04B4 &H6870 2 &h02:&h01
U=nll |ghd 2 &H04B4 &H6870 2 &h02:&h01
You will need to map the gun trigger via joy2key to "Y" for player 1 and "U" to player2. This then means any time Y or trigger is pressed, the keystates within mamehooker sends the recoil motion to the gun.
This is done this way because some of the games recoil outputs don't work/are not consistent etc and this is how to get round it.
Keep us updated on your build.
esoteric_rt
« Reply #9 on: November 29, 2023, 04:34:39 pm »
Thanks very much for the files,
I spent about 2hrs on this last night and managed to get Transformers and HOTD4 running with recoil and gun lights. I'll admit, this was a frustrating experience as its a bit complicated, instructions/info is limited and I had no experience with Mamehooker or Demulshooter before. But once I understood how all this worked together, its relatively straight forward. All the AHK files need to be altered as the paths in your AHK's are based on that Biohazard PC build and don't match my file locations. But that's easy enough to sort.
One other oddity that confused me. When testing the Aliens guns in Demulshooter, the crosshairs would not reach either side of the box, which limited the gun range in game. I then figured out that you can override the analog guns value in the Demulshooter drop down option. However after I saved the new values, the range in the demulshooter test didn't change. But once I start a game through the AHK file, the crosshairs reach the full limits of the screen, so all good.
I'll keep plugging away and look to finalize the computer side of things before starting on the cabinet around Xmas time.
Cheers!
ant2
« Reply #10 on: November 29, 2023, 05:12:10 pm »
It takes ages, especially when things don't work properly and you are not sure why. Things like missing visual libraries, not in admin mode, files being read from different locations etc.
Running the wrong demulshooter exe, running with incorrect flags/systems
I got the hang of it after some grueling hours..
You could always just download the biohazard build?
Yes, for the guns, calibrate in windows, then demulshooter,  then use the analog control overrides for the limits and i get full range.
Then some games will need to be calibrated within the service menu before they work.
The only thing I haven't done, that can be, is we can modify the rear gun output for each game. I.e in alien extermination it states ammo left, for one of the model2 games i modified it for remaining life (as ammo is unlimited).
If someone gets the time to adjust each of those in mamehooker ini files, then please upload. The issue is if we try and add a function that is incorrect/not supported it can crash the game.
If you find any other games that work well that I haven't got configured please let me know!
I am pretty impressed with the guns, they are really fun and work very well with the games I've configured.
 Hoping my second gun may arrive by next week...
ant2
« Reply #11 on: January 07, 2024, 12:15:07 pm »
After waiting 6 weeks for my second gun, it never arrived and was apparently returned to sender.
Was a lot of back and forth with seller and ali express, eventually got a partial refund, excluding shipping (shipping was  £35).
Ordered another one and it finally arrived.
Another thing I really hate is the lack of usb binding in windows 10.
 Because i built the cabinet on my main pc, i have several mice,  keyboards etc and when taking it downstairs to play on the tv i could never get the same plugin order.
Ended up reconfiguring all the emulators.  Mame i set up the mapping to physical devices.
Really happy with the set up, but was very time consuming figuring everything out!
dhoyosg
  • Last login:February 18, 2024, 04:38:10 am
« Reply #12 on: January 09, 2024, 07:26:55 am »
Thanks for info
ant2
« Reply #13 on: March 07, 2024, 08:30:50 am »
How to fix the USB devices from moving around:
Within mame you can hardset the gun orders using "devicemap" - so I did that.
example:
<mameconfig version="10">
   <system name="default">
      <!-- X-Arcade Version 1.0 input configuration file -->
      <input>
      <mapdevice
      device="Generic   USB  Joystick   product_00060079-0000-0000-0000-504944564944 instance_e2d070b0-7e62-11ee-8001-444553540000"
      controller="JOYCODE_1" />
      <mapdevice
      device="XinYeDigital product_687004b4-0000-0000-0000-504944564944 instance_62a17e60-7d5f-11ee-8001-444553540000"
      controller="JOYCODE_2" />
<mapdevice
      device="XinYeDigital product_687004b4-0000-0000-0000-504944564944 instance_ffd1f1c0-a644-11ee-8001-444553540000"
      controller="JOYCODE_3" />
      </input>
   </system>
</mameconfig>
For the other emulators there is no way of binding them. I got my labeller and printed the following on each of my USB's "gun1,gun2,cabinet,keyboard". I then put them in the order gun1,gun2,cabinet in to my front ports (this is just easier for me) and then usb keyboard in the back. I then configured everything i.e all the emulators,demulshooter, making sure mamehooker was sending to the right gun etc. Then that's it. just make sure you start your PC or plug in everything in that same order.
The bigger issue for me is that I am using my main PC and unplugging it from my desk and bringing it downstairs just to play.
IF you have it housed inside a permanent cabinet then i'd buy a USB hub, this way each of the ports will be powered on in the same sequence and never change from initial set up.
Prime91122
  • Last login:September 20, 2024, 07:36:51 pm
« Reply #14 on: September 11, 2024, 10:20:24 am »
How can you make the guns work with rpsc3 games for example Rising Storm? Does anyone have an ahk file to share and is recoil output possible or Joy2key way the only way?
oddeye45
  • Last login:May 04, 2025, 05:32:48 am
« Reply #15 on: January 02, 2025, 06:43:11 am »
Same as the OP, I wanted in on these guns so I pulled the trigger from AliExpress. Guns were £85 for the pair but the shipping was also £85 so £190 all-in to get them to the UK.
The most painful part is getting the set up on different systems. It took me ages to get as far as I have as it seems either not very many people have these guns or they are just not posting information anywhere. I currently have them fully working in MAME and in Teknoparrot. I have them intermittently working in Model 2, Model 3 and RPCS3/Namco 357. From what I can tell, the main issue is that the workarounds people use for other systems are assuming that it is looking for a mouse input and these guns will appear as joysticks. One workaround I have working is to use a program that converts joystick inputs into mouse inputs and, although this works, the software only allows for one controller to do this. I used this to get some stuff working on Namco 357 but then you can only play one player and it still requires Demulshooter and Mamehooker to get outputs (but no recoil as you cannot use Joy2Key and Joy2Mouse at the same time - or at least I couldn't get them to play nicely).
There is a guy on Youtube that has these guns fully working on Model 2, Model 3 and RPCS3 with full recoil and I have tried reaching out to him to find out how to do it but got no response. I have Gun4ir guns and, yes, I could use them for this but I bought these guns so that the full-auto shooters could be played somewhat authentically. I wish there was a place where we could upload all of the files and solutions that have been found so that this becomes easier for others in the future. In particular, I am always looking for ways to incorporate the gun counters into my games. I usually get it to display lives but on most games there is an ammo option. However, everytime I try to use that it either shows the digits duplicated (99, 88, 77...etc) or it just shows a single digit countdown but this doesn't match the actual ammo count in game. In Aliens it works properly as the game handles it and in FarCry I have it displaying the kill count, which also just works.
If anyone would like to take a look at my files and move the torch forwards, let me know and I'll upload a few.
dgrace
  • Last login:Yesterday at 12:41:11 am
« Reply #16 on: February 05, 2025, 12:29:55 am »
I would be interested in your files. I've got most games working with my 2 alien guns but some are still buggy and I'd be curious to look at your ini files. I don't really care for the keystates alternative, so I'm curious if I'm just not using the right codes. Thanks man
oddeye45
« Reply #17 on: March 20, 2025, 10:25:53 am »
Here are a couple of examples:
Jurassic Park (Teknoparrot):
[General]
MameStart=ghd 1 &H04B4 &H6870 8 &h04:&h00:&h00:&h00:&h00:&h00:&h00:&h00 , ghd 2 &H04B4 &H6870 8 &h04:&h00:&h00:&h00:&h00:&h00:&h00:&h00, ulk 1, ulk 2, uli 1 25 255, uli 1 1 255
MameStop=kls 1, kls 2, ulk1, ulk 2
StateChange=
OnRotate=
OnPause=
[KeyStates]
RefreshTime=
[Output]
P1_LmpStart=uls 1 54 %s%
P2_LmpStart=uls 1 9 %s%
LmpDinoHead=
LmpLogo=uls 1 1 %s%
LmpDinoEyes=
LmpRoof=
LmpMarquee=
LmpDash=
LmpFoliage=
P1_LmpGun_R=
P1_LmpGun_G=
P1_LmpGun_B=
P2_LmpGun_R=
P2_LmpGun_G=
P2_LmpGun_B=
LmpSeat_R=
LmpSeat_G=
LmpSeat_B=
LmpBenchLogo=
P1_LmpHolder=
P2_LmpHolder=
LmpSeatBase=
LmpEstop=
LmpCompressor=
P1_Ammo=
P2_Ammo=
P1_CtmRecoil=nll |ghd 1 &H04B4 &H6870 2 &h02:&h01
P2_CtmRecoil=nll |ghd 2 &H04B4 &H6870 2 &h02:&h01
P1_Life=ghd 1 &H04B4 &H6870 3 &h03:&h00:&h0%s%
P2_Life=ghd 2 &H04B4 &H6870 3 &h03:&h00:&h0%s%
P1_Damaged=
P2_Damaged=
Terminator 2 (MAME)
[General]
StateChange=
OnRotate=
OnPause=
[KeyStates]
RefreshTime=
[Output]
Left_Gun_Green_Led=
Right_Gun_Green_Led=
Right_Gun_Recoil=nll |ghd 2 &H04B4 &H6870 2 &h02:&h01
Left_Gun_Recoil=nll |ghd 1 &H04B4 &H6870 2 &h02:&h01
Right_Gun_Red_Led=
Gunblade (Model 2):
[General]
MameStart=
MameStop=
StateChange=
OnRotate=
OnPause=
[KeyStates]
RefreshTime=
[Output]
P1_LmpStart=
P2_LmpStart=
P1_GunMotor=
P2_GunMotor=
Credits=
P1_CtmRecoil=ghd 1 &H04B4 &H6870 8 &h02:&h01:&h01:&h00:&h00:&h00:&h00:&h00
P1_Damaged=
P2_CtmRecoil=ghd 2 &H04B4 &H6870 8 &h02:&h01:&h01:&h00:&h00:&h00:&h00:&h00
P2_Damaged=
So far I have everything working apart from Model 3 and Namco 357/RPCS3. Model 3 does work but it reassigns the gun id's everytime you restart the PC and I haven't found a way to stop it doing that. There is a way to do the RPCS3 setup as Dean from Shar-Kade has it working as per his videos on YouTube but, although I have contacted him regarding this, I assume he is very busy so I have not had a response. I still haven't fully figured out the LCD display thing so I can get it to show things like lives but no to correctly count ammo. It does also work with other emulators but, as I hav Gun4IR guns and RetroShooter RS3 Reapers I only use the Aliens guns on games that had static analogue guns.
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
« Reply #18 on: March 21, 2025, 06:08:15 pm »
Hi, I'm waiting my first Alien gun and I've not tested it yet, but I found this topic about Supermodel3:
https://forums.launchbox-app.com/topic/74512-how-to-automatically-set-correct-mouse-light-guns-bindings-in-supermodel-3-config-file/
mickael28
  • Last login:March 31, 2025, 05:56:29 pm
Doubts regarding the power supply for these guns
« Reply #19 on: March 23, 2025, 08:45:59 pm »
Hi guys, I don't know much about arcade cabinets. Thinking if this might be doable for a standard PC but have many 'basic' doubts regarding the power supply.
I saw the image in the attachment where the same white connector powers 12V + 24V + ground. And I don't know how that can be achieved yet.
I saw some arcade power supplies linked above, but I've not seen any which come with cables. What's the name of those cables for these connectors and to plug onto the wall socket to search for them?
And how can one physically connect 3 different cables into the same connector? I can't picture how that connection is made...
What's the name of that white connector with the 3 pins inside?
Protection wise, anyone knows of any kind of case/protection for these guns to not have those screws/cables exposed when there are kids around?
Cheers
« Last Edit: March 23, 2025, 10:10:49 pm by mickael28 »
  • Last login:Yesterday at 03:40:02 pm
« Reply #20 on: March 24, 2025, 12:05:07 am »
It's a molex connector but you can ignore that thing completely.   Cut it off as soon as you get the gun.   Switching power supplies normally have screw terminals so you just strip the wire and screw each wire to the appropriate voltage.  Of course, you could try and find the male version of that connector, but they are usually expensive, and the guns will need to be permanently mounted anyway.
The wires should all be safely tucked inside your cabinet, so they won't be exposed.   If you are talking about the gears under the gun those are typically coved with a metal box in the arcades, but a wooden or even plastic box could be fashioned quite easily.
mickael28
« Reply #21 on: March 24, 2025, 09:56:05 am »
Thanks for the details. I don't have space for a cabinet so I was thinking about just setting something up with one of these guns and the power supply. I'll have a thought about how I could protect both (the power supply and the gun gears) as I won't be able to purchase it atm, bad timing going on holidays shortly just when I saw this :)
Thanks again 🙏
mrbee
  • Last login:January 16, 2026, 02:40:54 pm
« Reply #22 on: April 05, 2025, 02:43:15 am »
Hey just wondering if you are willing to share the files you configured?
i have downloaded the biohazard set but would very much appreciate the files you made!!
Do you have an update on your build? guns still working ok?
im hoping to get my guns next week! had a shipping error last week but they have passed customs and on the way!
mrbee
« Reply #23 on: April 24, 2025, 06:24:23 pm »
Alrighty!
I have managed to build the case and get the guns all set up.
Building is fine, I just hate the software side of this.
Already ran into a strange hurdle.. this one being that I launch the game using the aliens deshaped.ex.. I connect one gun to the pc
it says one gun detected and i can calibrate it and play. no problems.
if i connect two guns, the intro screen says 2 guns detected but when calibrating the left gun has no effect at all. only the right player works!
so i guess this has to be run through teknoparrot for 2 player.
maybe the exe has been messed with to make it compatible with a mouse, thus disabling the i.d of player 1s gun so that it passes the check but isnt enabled any further perhaps.
running it through teknoparrot using direct input seems to be all good, except the crosshairs wont go exactly to the edges of the screen, even after calibrating in both windows and in the game itself.
the crosshairs are also a bit glitchy/twitchy randomly in teknoparrot.
but at least player 1 (left) is working now
i have made a full audio mod for this game if anyone is interested changing almost all sfx and music and even all fmv files music and sfx to be more authentic to the movie
SuperMagoAlex
« Reply #24 on: April 25, 2025, 04:02:14 am »
Hi, this is my build, I hope to test the software asap  :)
Vitaly17
  • Last login:November 20, 2025, 03:37:50 am
« Reply #25 on: April 25, 2025, 07:20:14 pm »
Alrighty!
You can set up control via directinput in teknoparrot and both weapons will work. This method is also suitable for Far Cry
mrbee
« Reply #26 on: April 26, 2025, 12:29:57 pm »
i tried far cry on teknoparrot and when i calibrate the guns, pressing the player 2 trigger makes the solenoid work on the player 1 gun. player 2 solenoid doesnt work.
really strange.
im buying a new usb hub to see if that does anything
mrbee
I am almost finished with the build now!
I made the gun case using an old military ammo container, themed it to the aliens marines.
Then built a base and monitor unit which is themed to a power loader crate and the power loader itself. It looks pretty cool, will upload pictures of it beginning of next week, just have some finishing touches to do (replace an old noisy fan I used with a new one and some paint detailing).
I have gone through every sound in the game to make it like the movie, including cut scenes and attract mode and found out some things about the game -
The sounds for attract mode and cut scenes can be stereo and high quality. All sfx of the game though, including music and ambience -the game only wants it as mono and 11khz! utter madness.
But I guess they wanted it to run in a really cheap pc.
I haven't yet found a way to get the game to stop using positional sounds, as they also have music as positional sounds so the music will play on the left speaker louder than the right and other janky things like that, Ive had to set the pc to output as mono as I can't figure out how to get it to play the positional sounds correctly. In mono everything sounds great.
As for the controls - the game is best run in teknoparrot. I have tried the guns natively using the pc aliensdeshaped.exe but only one gun seems to work properly and things get flipped round such as the left gun trigger activates the right guns solenoid and so on. Perhaps its just me but on 2 pcs now, no change.
I run it through teknoparrot and I can configure each gun easily, I am using two zero delay units (one in the gun case and one in the base unit for the coin and system menu) and in teknoparrot it picks these up straight away with no issues and no need for joy2key.
dgrace
« Reply #28 on: August 17, 2025, 11:24:16 pm »
Curious if anyone has any 3d print files they'd be willing to share for the alien gun cover. Thanks in advance.
  • Last login:Today at 03:17:12 am
« Reply #29 on: August 18, 2025, 01:19:23 am »
How about this one?
thingiverse.com/thing:3949905
dgrace
« Reply #30 on: August 19, 2025, 01:24:49 am »
How about this one?
Tried that. Unfortunately it only works with the Aliens extermination plastic control panel from AliExpress.
https://a.aliexpress.com/_mNAVR0V
« Reply #31 on: August 19, 2025, 10:23:38 am »
If you can provide precise X-, Y-, and Z-axis measurements for the inside of the cover and how large of a slot you need on the top, it is fairly easy to make a 3d printable shell in OpenSCAD.
Here's the code for a KADE MiniConsole+ cover that I designed six years ago.
- Should be easy to resize and move the holes from the ends to the top/bottom.
- Print the cover halves as oriented.  The hole in the "diving board" tab lines up with the hole on the thin flange of the other half.
Code: [Select]
// KADE miniConsole+ case (WIP)
// Variables are estimates -- awaiting accurate measurements.  Port openings have extra wiggle room.
// Define variables
screwdiameter = 4;    // Screw hole diameter
PCBwidth = 60;        // PCB width
PCBlength = 80;       // PCB length
PCBthick = 1.8;       // PCB thickness
componentheight = 22; // Component height
USBoffset = 10;       // Distance from PCB edge to USB
RJ45offset = 8;       // Distance from PCB edge to RJ45
DSUBoffset = 9;       // Distance from PCB edge to left side of D-Sub15
SecHalfMove = 60;     // Y-axis distance to move the second half of the case
// Number of fragments (polygon sides) used to render a full circle.
    $fn = 180; // Default = 180  Typical range = 6 - 360
    // 6 will render a circular hole as a hexagon, 8 will render a circular hole as an octagon.
    // Lower the number for faster rendering, raise the number for smoother rendering.
//  Make the part
// RJ-45 and USB side of case
difference(){ // Case body minus hollow, PCB slot, RJ-45 and USB holes
    // Case body
    hull() {
    translate([PCBwidth+14, 8+PCBthick+componentheight, 1+PCBlength/4])
    cylinder(h=2+PCBlength/2, d=4, center=true);
    // Upper right cylinder
    translate([14, 8+PCBthick+componentheight, 1+PCBlength/4])
    // Upper left cylinder
    translate([PCBwidth+14, 2, 1+PCBlength/4])
    cube([4,4,2+PCBlength/2], center=true);
    // Lower right cube
    translate([14, 2, 1+PCBlength/4])
    // Lower left cube
    } // End case body
// Holes to remove from case
    // Upper hollow
    color("green") translate([14+PCBwidth/2, 6+(PCBthick+componentheight)/2, 5+PCBlength/4])
    cube([PCBwidth-6,PCBthick+componentheight,5+PCBlength/2], center=true);
    // Lower hollow
    color("green") translate([14+PCBwidth/2, 4, 5+PCBlength/4])
    cube([PCBwidth-6,3,5+PCBlength/2], center=true);
    // PCB slot
    color("white") translate([14+PCBwidth/2, 4+PCBthick, 5+PCBlength/4])
    cube([PCBwidth+0.2,PCBthick,5+PCBlength/2], center=true);
    // USB hole
    color("blue") translate([7+PCBwidth-USBoffset, 9.7+(PCBthick*1.5), 5])
    cube([14,12,12], center=true);
    // RJ45 hole
    color("brown") translate([22+RJ45offset, 11.7+(PCBthick*1.5), 5])
    cube([16,16,12], center=true);
     } // End case body minus hollow, PCB slot, RJ-45 and USB holes
difference(){ // Left mount tab minus screw hole
    // Left mount tab
    translate([6, 1.5, 1+PCBlength/4])
    cube([12, 3, 2+PCBlength/2], center=true);
    // Screw hole
    translate([6, 2.5, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
    cylinder(h=10, d=screwdiameter, center=true);
} // End left mount tab minus screw hole
difference(){ // Right lower mount tab minus screw hole
    translate([22+PCBwidth, 1.5, 1+PCBlength/4])
    // Screw hole
    translate([22+PCBwidth, 2.5, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
} // End right lower mount tab minus screw hole
difference(){ // Right upper mount tab minus screw holes
    translate([22+PCBwidth, 4.5, 2+PCBlength/2])
    cube([12, 3, 4+PCBlength], center=true);
    // Screw hole 1
    rotate([90, 0, 0])
    // Screw hole 2
    translate([22+PCBwidth, 2.5, (2+PCBlength/2)+(PCBlength/2-8)])
    rotate([90, 0, 0])
} // End right lower mount tab minus screw holes
// DSub15 side of case
difference(){ // Case body minus hollow, PCB slot, and DSub15 hole
    // Case body
    hull() {
    translate([PCBwidth+14, 8+PCBthick+componentheight+SecHalfMove, 1+PCBlength/4])
    translate([14, 8+PCBthick+componentheight+SecHalfMove, 1+PCBlength/4])
    translate([PCBwidth+14, 2+SecHalfMove, 1+PCBlength/4])
    // Lower right cube
    translate([14, 2+SecHalfMove, 1+PCBlength/4])
    // Lower left cube
    } // End case body
    // Upper hollow
    color("green") translate([14+PCBwidth/2, 6+(PCBthick+componentheight)/2+SecHalfMove, 5+PCBlength/4])
    // Lower hollow
    color("green") translate([14+PCBwidth/2, 4+SecHalfMove, 5+PCBlength/4])
    // PCB slot
    color("white") translate([14+PCBwidth/2, 4+PCBthick+SecHalfMove, 5+PCBlength/4])
    // DSub15 hole
    color("blue") translate([-6+PCBwidth-DSUBoffset, 10.7+(PCBthick*1.5)+SecHalfMove, 5])
    cube([40,14,12], center=true);
     } // End case body minus hollow, PCB slot, and DSub15 hole
    // Left mount tab
    translate([6, 1.5+SecHalfMove, 1+PCBlength/4])
    // Screw hole
    translate([6, 2.5+SecHalfMove, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
    translate([22+PCBwidth, 1.5+SecHalfMove, 1+PCBlength/4])
    // Screw hole
    translate([22+PCBwidth, 2.5+SecHalfMove, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
    translate([22+PCBwidth, 4.5+SecHalfMove, 2+PCBlength/2])
    // Screw hole 1
    rotate([90, 0, 0])
    // Screw hole 2
    translate([22+PCBwidth, 2.5+SecHalfMove, (2+PCBlength/2)+(PCBlength/2-8)])
    rotate([90, 0, 0])
} // End right upper mount tab minus screw holes
« Reply #32 on: August 21, 2025, 12:39:40 am »
It feels like 3d printing might be overkill.   Most positional guns have a simple metal cover, usually a rectangle with the corners lopped off.
shabaj
  • Last login:January 15, 2026, 05:16:38 pm
« Reply #33 on: January 15, 2026, 05:15:22 pm »
Hi,
I have ordered 2 aliens extermination usb guns and need some advice on the power supply. I will order the same as ant2 recommended, the 12v and a seperate 24v.
I just need clarification on how to connect the 1 ground wire between the 2 power supplies. I didn't quite understand how you would connect them together as one post suggested?
Another questions is does the recoil really need more than 5amps because there is 1 power supply that allows both 12v and 24v in 1 supply but the highest amp for 24v is 5amp only and I read 6amp is better but for what reason?
Thanks in advance. If I don't get a reply I might start a new topic on this.
