Author Topic: new Joyboards  (Read 4366 times)
mamemia
  • Last login:December 14, 2013, 02:17:50 pm
    • BLACK.BOARD
new Joyboards
« on: June 04, 2002, 02:07:03 am »
Hi
I am a German Mame Fan, and i build my Controls with a SNES-Topfighter Joybords, here some new Projects:
Gru
mamemia
    • BLACK.BOARD
Re: new Joyboards
« Reply #1 on: June 04, 2002, 02:25:13 am »
Work with Plexi-Glas (4mm) ... ;) and the Stick are orginal nintendo :)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Re: new Joyboards
« Reply #2 on: June 04, 2002, 02:37:26 am »
Whee, these look really good!  :D :D
How did you made the overlay-printings? Glossy-paper? Or is it directly reversed-printed on the plexiglas itself?
Carsten, also from Germany ;)
mamemia
    • BLACK.BOARD
Re: new Joyboards
« Reply #3 on: June 04, 2002, 04:11:28 am »
The Overlays was printing on Transparent Inkjet Labels from Zweckform No.4723 (Din A4), und werden Seitenverkehrt gedruckt, anschlie
Carsten Carlos
Re: new Joyboards
« Reply #4 on: June 04, 2002, 04:34:18 am »
Thanx, even with article-number - I'll have a look at these  :D
Guess this transparent labels could also be a good idea for making a marquee. Printing directly on plexi/Lexan is quite expensive (about 100 Euro / $90).
This controls are sure a lot of fun to play with!
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
Re: new Joyboards
« Reply #5 on: June 04, 2002, 06:19:36 am »
F.Y.I
those stix with the black knobs are not original nintendo joysticks.......  nintendo joystix have a very short shaft.
if you need a pic say so..I have a few nintendo cabs and a joystic that I can take a pic of for ya :)
d88
1UP
  • Token Junkie
    • 1UPArcade
Re: new Joyboards
« Reply #6 on: June 06, 2002, 05:43:05 pm »
The Overlays was printing on Transparent Inkjet Labels from Zweckform No.4723 (Din A4), and if side-twisted are printed, afterwards the printed side(page) is pasted with white DcFix. Then the finished sticker is stuck from below on the Perspex disc etc... ;)
Okay, I had to re-translate that last part, looks like something got lost after (Din A4)!  So it sounds like you reverse-printed on clear adhesive sheets, sprayed (?) the backside with some kind of white fixative to fix the ink and make it opaque, then stuck them to the bottom of the plexiglass.  Has anyone tried having a print shop print something on adhesive film?  Just wondering what the cost would be...
My other job...
mamemia
    • BLACK.BOARD
Re: new Joyboards
« Reply #7 on: June 12, 2002, 10:54:16 am »
NEW!! Asteroids Panel ;-)
Gru
Carsten Carlos
Re: new Joyboards
« Reply #8 on: June 12, 2002, 11:54:15 am »
I really like your joyboards! Looks like loads of fun! :D
Should have seen these before, maybe then I would build only small controlpanels, too, instead of this big and unbelievable expensive upright-cabinet! ;D ;D ;D
