Author Topic: Pacman arcade party video issue  (Read 616 times)
1supercomputertyler
  • Last login:September 06, 2023, 06:48:07 pm
« on: September 06, 2023, 06:37:48 pm »
I have a coin-op pacman arcade party with 2 coin slots, the video output has weid dark lines that go across, slow down, stop, go away, and then go in the opposite direction. It's almost reminiscent of a sync issue. I tried connecting another vga monitor and see similar output. I almost wonder if it's phase and clock settings but they don't seem to fix it. Could this be a power supply issue or is this the gpu starting to go out. It has done this for several years but seems to have gotten a little worse. Any recommendations on how to diagnose
grantspain
  • Last login:Today at 05:53:20 pm
Re: Pacman arcade party video issue
« Reply #1 on: September 06, 2023, 11:06:28 pm »
it sounds like an earth issue or a capacitor failing on the monitor or even a power supply problem
can you connect an external monitor to rule that out
lilshawn
  • Last login:Today at 01:03:34 pm
« Reply #2 on: September 07, 2023, 11:58:09 am »
not sure of this one specifically, but other games I've had with symptoms like this where GPU capacitors are going bad.
