Author Topic: Let’s go jungle with Lindbergh PC from Sega. Disk copy  (Read 2327 times)
Georgegiai
  • Last login:August 28, 2024, 07:34:35 am
« on: September 03, 2023, 02:08:37 pm »
Hello everyone
My HDD from Let's Go Jungle, which was mounted on a Lindbergh computer, broke. I have the oringal DVD and I don't know what to do to get the machine working again.
The machine is the let's go jungle cabinet from Sega.
Can someone help me?
Should I copy the DVD to a hard drive?
What program should i copy it with?
Should i watch out for something?
grantspain
Re: Let’s go jungle with Lindbergh PC from Sega. Disk copy
« Reply #1 on: September 06, 2023, 11:35:07 am »
install a 40gb or 60gb or 80 gb ide hard drive with jumpers matched to original( i think its slave)
you need a external usb dvd drive to load the recovery disk, remove the mini usb adapters on the front panel of the lindbergh and you can use the standard usb sockets for the external drive
switch on machine, insert disk pretty quickly and it will automatically load the software
Georgegiai
« Reply #2 on: September 07, 2023, 11:17:17 am »
I have a lot of HDD same as original (wd400bb) every time i try to install from original DVD this message appears (check attachment)
need I to make the hdd format before ?
