Author Topic: TETRIS now available for Megatouch Ion 2014  (Read 1480 times)
Megatouchmike
  • Last login:May 29, 2024, 07:21:49 am
« on: May 18, 2023, 07:43:54 am »
Testing the waters to see if there's an interest in new games for Megatouch.  I've ported an open source version of TETRIS to Ion 2014.  Shows up in the puzzles menu and saves high scores like any other game.
I've had about a dozen or so people successfully test this update. If interested, I'm happy to share.
The update is a ~1.5mb file that you will need to save to a fat32-formatted thumb drive. Boot the megatouch with the thumb drive inserted, and the update should automatically install.
This will only work on original unmodified/unhacked software.
« Last Edit: May 18, 2023, 07:48:58 am by Megatouchmike »
Spank
  • Last login:May 30, 2024, 05:16:22 pm
  • I like to help out.
Re: TETRIS now available for Megatouch Ion 2014
« Reply #1 on: May 18, 2023, 11:17:40 am »
That looks cool, I'll like to try it out.
When you tap down does it drop the block or go faster if held?
Wonder if Tetrinet is still around. That was a great multi player version of Tetris. would be nice to set up a few megatouches and play against each other.
Am I the only one with multiple games linked? You don't see too many people talk about multi games.
New games added sounds like a great idea, Bring back uno and skeeball I think that was a better version of the later roller game.
  • Last login:Yesterday at 04:46:25 pm
« Reply #2 on: May 18, 2023, 11:46:18 am »
interesting! i'm up for new games!
On the backside, what kinds of games can be "ported" into the megatouch? there are piles of linux games with touch support on "itch.io" could some of those be slotted into it or is there a specific format/particular type of code that has to be used in the game system nativity to run?
Megatouchmike
« Reply #3 on: May 18, 2023, 06:46:03 pm »
Faster
Is there a Linux port for tetrinet? Does the windows version run under wine? That's a great idea
Uno for sure. Already have that working on another build. Skee ball will be more difficult due to the 3d rendering and driver issues
Megatouchmike
« Reply #4 on: May 18, 2023, 06:47:42 pm »
Anything that I can get to compile on a nearly 15 year old OS. I've had luck with some gtk and python games. If there are any you want to see, let me know
mahkeymike
  • Last login:Today at 10:45:20 am
« Reply #5 on: May 18, 2023, 06:56:51 pm »
Lemmings, return fire, and incredible machine.
Megatouchmike
« Reply #6 on: May 18, 2023, 07:35:59 pm »
Find me a version of Dosbox that supports touchscreen
Spank
« Reply #7 on: May 19, 2023, 04:16:58 pm »
Faster
http://servers.tetrinet.fr/ lists some servers still active for tetrinet.
https://en.wikipedia.org/wiki/TetriNET  does list there that there is a Linux version. I really don't know how hard it would be to find a good source for the files now.
I haven't played in 20 years. Looks like there are a few different versions of the game that came out.
Would they use different drivers in different years? I could see adding more in newer versions for the intel board, but they didn't remove support for the older boards. I think 2009 was the earliest that supported the intel board. Skeeball was in 2008 if I remember correctly. I think Uno was 2007, May have been together at one time. I could be off on the years.
