Author Topic: How to reduce glare from flat glass bezel?  (Read 1258 times)
alank2
  • Last login:June 25, 2023, 10:05:48 pm
« on: March 03, 2004, 09:52:48 am »
I got a 23" x 21" flat monitor bezel that is tempered smoked 3/16" trick.  It looks really great, but the glare from the monitor is easily visible in most lighting.  Is there a way to reduce this via some coating or plastic coating?  Any ideas?
Thanks,
Alan
Witchboard
Re:How to reduce glare from flat glass bezel?
« Reply #1 on: March 03, 2004, 01:49:09 pm »
I'm confused.  You see the glare from the TV on the backside of your glass?
Stingray
« Reply #2 on: March 03, 2004, 01:50:34 pm »
I'm confused.
Me too. I totally don't understand the question.
-S
alank2
« Reply #3 on: March 03, 2004, 01:56:40 pm »
Sorry guys, I should have explained better!  Yes, the glare from the TV on the backside of the glass is the issue.  Any ideas on how to reduce that?
Thanks,
Alan
Stingray
« Reply #4 on: March 03, 2004, 02:03:56 pm »
That's pretty strange. I didn't think you'd be able to see glare on the inside of the glass. My cab has tinted plexi and I don't have this problem. Maybe the plexi has some kind of anti-glare coating on it.
-S
Witchboard
« Reply #5 on: March 03, 2004, 02:10:11 pm »
How thick is your glass?
alank2
« Reply #6 on: March 03, 2004, 02:14:54 pm »
It is 3/16 thick, tempered and tinted.  Here is a picture that will show it:
http://home.earthlink.net/~alank2/glare.jpg
I've circled the areas where you can see the glared items...
Thanks,
Alan
Witchboard
« Reply #7 on: March 03, 2004, 02:22:35 pm »
Sure enough, I can see it with Inky.  I would just say that it's just noticable due to the contrast of the light areas with a dark background.  I'm not sure if there's a way to fix it.  Maybe Stingray can see if he get's similar results on his plexi.
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #8 on: March 03, 2004, 02:29:38 pm »
Maybe it's just the picture but your image appears really bright.  I think toning down the brightness or color saturation on your monitor or TV could help reduce the glare some.
Stingray
« Reply #9 on: March 03, 2004, 02:41:21 pm »
Nope. No glare whatsoever under any lighting conditions. However, my monitor is set back about five inches from the plexi, which could be a significant factor.
-S
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #10 on: March 03, 2004, 07:05:19 pm »
they sell satin clear  spray paint. maybe that'll help? It's made by Krylon.
Witchboard
« Reply #11 on: March 03, 2004, 08:56:51 pm »
-S
That could be a factor.  I would be interested in how far back his monitor is.  If it's right up against the glass then maybe thats the problem.
I think spray painting with satin would be a very bad idea.  You might as well have bought frosted glass, and it would probably compound the problem.
CitznFish
« Reply #12 on: March 03, 2004, 10:21:51 pm »
-S
It's perfectly clear. I've used it on Brass outdoor lights. It just doesn't have any gloss to it.
Witchboard
« Reply #13 on: March 04, 2004, 12:01:39 am »
Ah, misunderstood what you meant.  I was wondering what you were smokin'.  ;D
