Author Topic: CRT Emudriver not installing winxp x64 (Naomi Cab build)  (Read 1641 times)
Deathblow81
  • Last login:April 24, 2024, 01:16:39 pm
« on: March 25, 2023, 08:10:26 am »
Hi All,
I'm trying to build a machine for a Naomi cab.....
I want to use groovyArcade as it seems to be the best?
I have :
H81M P33
I think an i5@3.2
Win xp x64
I tried the graphics card I had in an old PC
Firepro V5900
Was a bit too fruity and I couldnt work out how to get the install to take, the installer couldnt find the device (was properly installed).
Bought a different card HD5450
Now I cant install Emu driver 2.0 due to not having "administrator privileges" despite being the admin.
Any help with any of the above?
Also what do I need to consider when pairing with a Naomi monitor (I havent taken the back off in an age).
Thanks man!
buttersoft
  • Last login:Today at 04:39:06 pm
  • Is running at 15kHz
Re: CRT Emudriver not installing winxp x64 (Naomi Cab build)
« Reply #1 on: March 25, 2023, 07:50:02 pm »
crt_emudriver v1.2b and older work on XP. This is a legacy version, not updated and not recommended.
crt_emudriver 2.0 works on Win7/10. Make sure to read the info in the first post of the download thread before selecting the version you need. There is one that works with your Radeon HD 5450 - http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=295
GroovyArcade is for Linux OS. GroovyMAME is for Windows. crt_emudriver 2.0 is required for newer versions of GroovyMAME. Newer versions of MAME or GM are much easier to find roms for.
A Naomi cabinet would typically have had a 31kHz (640x480p) monitor in it - you should find the model number on the CRT chassis (the big electronics board, not the tube) and check google. GroovyMAME and crt_emudriver target 15kHz (480i/240p) monitors. Assuming you want to run primarily 15kHz games (Most pre-noami games were 15kHz - CPS1/CPS2/Neo-Geo/etc) there's nothing stopping you using GM, but it's a very slightly stepper learning curve than using regular MAME with a 31kHz monitor. And i'm not an expert in using it that way.
Deathblow81
« Reply #2 on: March 26, 2023, 07:59:22 am »
Thank you Buttersoft!
I noted that, but thought it advised using the latest 2.0 with this card, but with xp in the mix....will try now.
Cheers!
Deathblow81
« Reply #3 on: March 26, 2023, 01:18:29 pm »
Yes, aiming for CPS1 & 2, I've been reading shedloads already, stuck messing with xp, might go win 7.
