Author Topic: Vertical Hantarex Polo Star problem  (Read 2571 times)
azeitona
  • Last login:November 21, 2024, 11:02:16 am
« on: March 17, 2023, 10:02:35 am »
Hello everyone on the forum
I bought a broken 28" Hantarex Polo Star set.
I already checked the possible causes and nothing.
I don't know what the ideal voltage for this chassis is.
The maximum voltage I have is 120V, which is weird.
Already replaced the TDA 1675A.
Is it normal to have a short between the dissipating part of the TDA 1675A and the dissipating aluminum?
grantspain
Re: Vertical Hantarex Polo Star problem
« Reply #1 on: March 17, 2023, 12:45:54 pm »
do you mean you have vertical collapse
if so then vertical ic and safety resistors need replacing/checking, vertical ic does normally have insulation sheet on polostar although I do not know if it is critical or not
check r32 1r metal oxide resistor, test 25v at sp5
check r105 2r7 metal oxide resistor, test 25v at at r105
azeitona
« Reply #2 on: March 20, 2023, 08:11:31 am »
I already measured the vcc in the TDA1675 and I have 25V.
Now a bar appears and I don't see what it is.
Is it normal for SP37 +VB to have a maximum of 128V?
What is the correct volt on this chassis?
https://imgur.com/a/3ZdStbS
grantspain
« Reply #3 on: March 20, 2023, 10:59:41 am »
what happens if you remove the vga signal and adjust screen so you can see a raster
azeitona
« Reply #4 on: March 20, 2023, 01:17:28 pm »
Above all I want to thank you for your help.
I don't have a video signal connected, neither to the vga input nor to the arcade input.
It was supposed to fill the screen with brightness.
I don't understand
https://imgur.com/a/61BSqZv
grantspain
« Reply #5 on: March 21, 2023, 03:11:02 am »
read vbatt at D20, should be 69-71v
azeitona
« Reply #6 on: March 21, 2023, 02:00:35 pm »
I measured on the D20 and I have 69.4V
grantspain
« Reply #7 on: March 21, 2023, 06:12:36 pm »
voltages correct
have you attached a video signal yet?
azeitona
« Reply #8 on: March 22, 2023, 09:38:12 am »
No, I haven't done it yet, but I know that without video the screen cannot have a bar. I think I'm not sure
https://imgur.com/a/S4RvddO
grantspain
« Reply #9 on: March 22, 2023, 10:50:43 am »
long time since i worked on a polostar but pretty sure they act strange without a signal attached
just try a 640 x 480 vga and see what happens
