Author Topic: Crt emudrivers 25khz monitor and 640x480 resolution need Calamity Help  (Read 3084 times)
xbrunox
  • Last login:August 30, 2025, 05:03:06 pm
Hi Calamity.
I have a problem with my 25kHz monitor that I have never had before.
I reinstalled the crt emudrivers and i have a problem with resolution 640x480 i
Before the new one I was able to view it in full screen.
Now, however, it displays it compressed only in the lower part of the monitor.
If I remember correctly, the resolution was seen by arcadeosd as native but now it is seen as custom
I am attaching a photo of the mistake.
Can U help me? Thanks
Calamity
  • Moderator
  • Last login:Today at 03:17:25 am
  • Quote me with care
How can 480i work at 25 kHz at all?
Steps to create a log:
xbrunox
I really do not know...
But I can assure you that before updating the drivers it worked perfectly and could be seen in full screen. And despite being an interlaced frequency the flicker was really low. It was a perfect resolution for all those applications designed to run at 640x480 by default.
And I can also guarantee you that my crt is single frequency fixed at 25khz.
xbrunox
OK I've solved! My monitor configuration in ini file was the problem!
xbrunox
These are 2 screens of a 640x480i in a 25khz monitor.
Calamity can u explain?
makya
  • Last login:December 05, 2025, 06:31:07 am
Hello,
I would say that a small display area is expected when you have 480i@60Hz and 25 kHz .
In this case more time will be allocated to blanking (compared to optimal 768i), so basically you get a 480 lines area drawn into a 768 one.
The curious thing is the fact you had a correct display before.
Did you make any modification to your monitor adjustement pots since then? If not then maybe your monitor secretly supports 15 kHz and was in this configuration for 480i without you knowing.
« Last Edit: March 20, 2023, 08:58:22 am by makya »
xbrunox
Now the problems are solved! I've solved modifying my monitor.ini. The snaps are of a correct full 640x480i on a 25khz!  The question is... Why I can see a 640x480i if my monitor specs start at 600i and end at 768i? What I exactly see? Is just for my curiosity
makya
I would like to know too. Can you share screenshots of arcadeosd, 640x480i, modeline menus please?
xbrunox
Are in the previous post I can't modify are marked as native
