Author Topic: Mortal Kombat 2 Wiring Harness  (Read 3476 times)
Thetauri1999
  • Last login:May 12, 2023, 05:16:16 pm
« on: March 06, 2023, 02:22:31 pm »
Can anyone post a link to the wiring harness I would need to replace the original wiring harness for the joysticks and buttons for a dedicated MK 2 arcade game?
  • Last login:Today at 01:31:50 am
Re: Mortal Kombat 2 Wiring Harness
« Reply #1 on: March 06, 2023, 05:02:06 pm »
According to the KLOV entry about this cabinet, Mortal Kombat II uses a standard JAMMA harness on connector P1.
- Any standard JAMMA harness will be fine as long as it has the -5v lines for audio and you check that pins 25, 26, c, and d are not connected to be sure that you don't get a mis-labeled "CHAMMA" (Chinese JAMMA) harness.
MKII also uses a 4 wire "kick" harness on connector P5 with "Low Punch" and "Low Kick" for P1 and P2.
Here are the pinouts for MKII wiring.
https://www.arcade-museum.com/pinouts-game/8756.html
