Author Topic: New to Retro Mod. Light up marquee with PC  (Read 8661 times)
modernfx
  • Last login:May 22, 2025, 10:37:46 am
« on: January 24, 2023, 12:40:07 pm »
Hello everyone.
I am somewhat new to the retro scene and also to modding arcade 1up cabinets.
I have the street fighter vs Capcom cabinet which I guess I have now repurposed.
I have done the 20" Dell Monitor upgrade, Control deck upgrade (usb), and have a pc running retrobat.
Anyway, I have everything powering up properly but I need to figure out if there is a way that I can have the marquee light up
once the computer turns on.
Is there a power to usb adapter of some sort? How have others solved this issue when using the stock arcade 1up marquee and a PC?
Thank you in advance to those that take the time to answer.
Best.
modernfx
Re: New to Retro Mod. Light up marquee with PC
« Reply #1 on: January 29, 2023, 07:21:56 pm »
I figured it out. I removed the LED lights that it had and replaced them with ones that are USB driven.
LTC
  • Last login:October 31, 2025, 12:24:07 pm
« Reply #2 on: February 23, 2023, 08:15:13 pm »
You Dell 20" should have a 12vdc out plug on it.
« Last Edit: February 27, 2023, 10:37:30 pm by LTC »
SNAAKE
  • Trade Count: (+29)
  • Last login:November 24, 2025, 12:30:06 pm
« Reply #3 on: September 03, 2023, 03:50:12 pm »
just plug this in to the dell monitor port and good to go?
https://www.diyretroarcade.com/products/led-strip-for-arcade1up-marquee-kit?
