Author Topic: Replacing 60 in 1 jamma VGA setup with Raspberry Pi  (Read 1802 times)
bluecoffee
  • Last login:January 22, 2023, 03:29:51 am
« on: January 22, 2023, 02:57:23 am »
I have a 60-in-1 board connected vai a JAMMA harness. I'm using the VGA from the 60 in 1 to run a VGA flatscreen monitor.
I would like to swap the 60in1 for a RetroPie setup, by replugging the Jamma harness into a new board, but still continue to use the VGA monitor. It's a two-player cabinet with 6 buttons and a joystick each.
What's the simplest way to do this?  Ideally I'd like to avoid soldering tonnes of pins onto an adaptor, and a Raspberry Pi to JAMMA adaptor https://pcbjunkie.net/index.php/raspberry-pi-to-jamma-adapter/  seems like overkill, as I don't need analgoue CRT video output.  It also has high voltage capacitors on it, which I don't want as I don't need to risk being zapped...
Is there any board that would allow for a straight swap, plug and play from my Jamma harness to the Pi?
Should I wire an iPac board to a Jamma connector? Is there a pre-built solution somewhere?  Or something completely different?
Many thanks
ericball
  • Last login:March 13, 2025, 11:01:47 am
Re: Replacing 60 in 1 jamma VGA setup with Raspberry Pi
« Reply #1 on: January 22, 2023, 10:47:16 am »
What you want is something like the XinMo 2P controller which will turn the joystick & buttons into a USB controller for the Raspberry Pi.  Then you will need something to connect the Raspberry Pi to your VGA monitor - either an HDMI to VGA adapter or board which connects to the GPIO pins.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« Reply #2 on: January 22, 2023, 04:06:36 pm »
If you do some kind of HDMI to VGA, better look into any latency issues before you invest in it.
