Author Topic: would 24khz do better for vertical games running on horizantal screen?  (Read 2371 times)
chriszhxi
  • Last login:February 22, 2025, 03:48:08 am
I'm running Groovymame for my New Astro City with MS9-29 in 15khz. When playing vertical games, Groovymame and CRT emudriver switches to some interlaced resolution.
So my question is, if I put my chassis in 24khz or get a 15k/24k auto switch chassis, would those vertical games run on better non-interlaced resolution?
makya
  • Last login:December 05, 2025, 06:31:07 am
Re: would 24khz do better for vertical games running on horizantal screen?
« Reply #1 on: January 18, 2023, 05:26:24 am »
Hi, according to typical crt_range for 24 khz it seems you can achieve 384 to 400 lines in progressive fashion.
arcade_25
      crt_range0  24960-24960, 49.50-65.00, 0.800, 4.000, 3.200, 0.080, 0.200, 1.000, 0, 0, 384, 400, 768, 800
So yes it can be beneficial for some vertical games run on a horizontal monitor.
chriszhxi
« Reply #2 on: January 29, 2023, 11:06:29 am »
arcade_25
Thanks, I tried some vertical games on tri-sync monitor, it indeed switched to 24khz mode.
