Author Topic: Best "sandwich" combo for 3/4" total?  (Read 1320 times)
Justin
  • Last login:September 08, 2025, 11:37:06 am
    • Centipede MAME cabinet
« on: January 17, 2023, 08:07:49 pm »
I want the top of my control panel to be exactly 3/4 inch total.  What's the best way to sandwich artwork, lexan, and MDF to achieve exactly 3/4" and use my 3/4 t-molding?
I only find 1/2in and 3/4in MDF!
"3 warps to Uranus" -- so I stopped playing!
Tommy714
  • Last login:November 02, 2024, 06:34:59 pm
Re: Best "sandwich" combo for 3/4" total?
« Reply #1 on: January 17, 2023, 08:28:59 pm »
Don't forget, if your using artwork on the surface, and t-molding on the edges, you can use particle board.  Or, if you want to get a little more expensive, they make Baltic Birch plywood in a lot of thicknesses.
Both have the added benefit of not being as heavy as the MDF.
My most recent project was 5/8" particle board + Formica Laminate and it was perfect for 11/16" chrome t-molding.
Justin
« Reply #2 on: January 17, 2023, 08:45:53 pm »
Im partial to mdf but maybe I should switch to particle board?  I'll be using a CNC at the local maker space.   I think it should cut it cleanly on both materials.  I think mdf is absolute best for cleanliness though.
  • Last login:Yesterday at 05:56:49 pm
« Reply #3 on: January 18, 2023, 12:41:15 pm »
Bro, countersink those joysticks.  Or use longer shafts.
Justin
« Reply #4 on: January 21, 2023, 08:21:39 am »
Looks like 5/8 in MDF can be found.  Add a 1/8in lexan sheet and I'm good to go.
« Last Edit: January 21, 2023, 11:36:03 pm by Justin »
