Author Topic: Brooks board how to set default player 1 and 2  (Read 886 times)
tuanny87
  • Last login:February 11, 2023, 01:27:24 am
« on: November 18, 2022, 03:13:14 am »
Hi guys how do you guys set default player 1 and 2 on PC using the brooks board. sometimes my player 1 becomes player 2 on reboot then i swap the boards around and its fine for some time then it gets swapped around again. using windows 11 cant figure out how to set default player 1
tried using devcon and running the bat file on shutdown/startup  to reboot the usb in the correct order but the file bat file doesnt work as it requires me to right click and run as adminstrator. tried all sort of codes but cant get it to run automatically. only works if i manually click the files before shutting down and booting up.
https://forum.arcadeotaku.com/viewtopic.php?t=39240
anyone else has a better solution that can be done thu softwares? or scrips?
