Author Topic: Some Cocktail cabinet questions  (Read 1464 times)
marcuskeeler
  • Last login:November 09, 2022, 09:35:03 pm
« on: November 06, 2022, 05:27:04 pm »
Got My Cocktail cabinet build up and running and slowly adding the roms I want into the MAME structure.
So my build is as follows:
Arcade1UP Cocktail Cabinet
HDMI Adapter for the screen
Windows 10 PC
USB Controls
The machine boots into windows and I run Mame from there. Ultimately I'll have the machine start Mame directly but I'm still configuring.   I had to rotate the windows screen 90 deg to make it more practical for setup etc
So I have a bunch of roms running ok, for the most part. One thing I cannot fix though is the way the joystick interacts with the Mame front end.  The up/down movements of the joystick actually moves the cursor action left/right while The Left/Right movement of the joystick is how I navigate up/down in the mame interface.   ::)
Sounds like a simple fix but for the life of me I cannot rotate that joystick orientation 90 degrees.
Most of the games work fine straight out the gate, it's JUST the Mame interface...
Any ideas?
Cheers
  • Online Online
  • Last login:Today at 10:49:44 am
Re: Some Cocktail cabinet questions
« Reply #1 on: November 06, 2022, 09:08:17 pm »
Go to the MAME "Input (general) -- User Interface" menu.
Remap the "UI Up", "UI Down", "UI Left", and "UI Right" inputs.   ;D
marcuskeeler
« Reply #2 on: November 06, 2022, 09:13:53 pm »
Done it a million times, it does absolutely nothing. I even mixed it up, inputting deliberately wrong settings, it literally ignores it
  • Online Online
« Reply #3 on: November 06, 2022, 11:00:50 pm »
That's odd.   :dizzy:
Confirmed working with either keyboard or joypad in MAMEUIFX v0.152 and regular MAME v0.238 here.
- The inputs work with the new keystroke/joypad values as soon as they are remapped.
- Works in the MAME "TAB" menus for both versions.
- Works in the MAME built-in UI game selection menu, but not in the MAMEUIFX game selection menu.
  *grasping at straws*
Have you tried bringing up the menu and remapping while a game is running? (this is how I did it)
Can you remap game inputs? (might be a file set to read-only)
Is there anything in your ui.ini that looks relevant? (don't see anything in mine, but yours may be different)
Have you tried rotating using ror or rol in mame.ini?
- These options rotate the screen orientation and the joystick menu navigation.
- With ror enabled as shown below, up on the joystick moves toward the right of the screen i.e. top of the menu.
Code: [Select]
# CORE ROTATION OPTIONS
rotate                    1
ror                       1
rol                       0
