Author Topic: LEDBlinky, Mame, Gorf  (Read 1015 times)
CommanderRaven
  • Last login:October 19, 2022, 08:02:38 pm
« on: October 19, 2022, 08:02:38 pm »
Hello everyone,
I just hooked up a Ultramarc Pacdrive.  I have led's on ports 1 to 7.  1 to 6 will be the GORF rank lights, and 7 will be the fire button led.
LedBlinky is configured, and sees all 7 of my LED's.
I've gone into the MameOutputs.ini file and added the section GORF.
I added LAMP1 to LAMP 7.  I assigned them to PC,1, 1 to 7, 1.   The last number intensity, I have a single solid bulb.  I tried 1, 24, and 48 in for this parameter.
In LedBlinky Input Map, it see my pacdrive.  It's called Pac-Drive (Ultramarc), controller ID is 1, Active is yes, Mapped yes.
Ports 1 to 6 are defined as RANK1 to RANK6, and FIRE.  LED Type Single.  Input Codes None.
The mame output test, I see mame send Lamp7, and the output shows PD,1,7,1 for fire.
But the led isn't lighting up.
I tried the mameoutput.ini file a couple different ways.
I tried PACDrive,1,1,1
PD,1,1,1
RANK1
I saw of these  show in the Output Test.
But no lights.
What am I missing?
Mame output
