Author Topic: Lichtknarre: Unmodified Wii remote as a sight accurate Lightgun using 2/4 LEDs  (Read 40235 times)
karoloydi
  • Last login:March 02, 2024, 02:24:14 pm
Just received my Overshot (buckshot) gun! Got it for only £5, cause the nunchuch part does not work.
I think I can still fix it. The nunchuck attachment broke off and fell inside.
The trigger and reload still work well.
I just mapped the start button to the trigger and set the games to freeplay for now.
Playing house of the dead was very good :)
ZTylerDurden717
  • Last login:January 07, 2024, 12:52:28 pm
I had assumed non button-pressed off-screen reload would only work with dolphin emulator. Turns out i can do it perfectly well with latest pcsx2.  Does anyone have off-screen reload working for them in other emulators? Which ones and how did you do it?
Demul and Technoparrot also suppport this
Awesome thanks for the info.
I'd be interested in Demul.  So all you had to do was calibrate in the test menu for whichever game and it allowed off-screen reloading? Vjoy mode using demulshooter?
karoloydi
Yes, vjoy mode and demulshooter. I don't remember about the test menu. You might not need to do that.
ZTylerDurden717
Confirmed this works with HotD2 demul!  But not possible with Confidential Mission.  Still pretty cool.
« Last Edit: November 19, 2023, 06:39:53 pm by ZTylerDurden717 »
karoloydi
I tried to use Lichtnarre with Guitar Hero Arcade, with my guitar hero wii guitar, but the buttons are not recognised.
Does anyone know why?
I thought they worked as a nunchuck.
Fusselkroete
  • Last login:April 16, 2024, 12:56:20 pm
  • sup dudes?
No this is an extra peripheral. what are the benefits to use this in LK? Sounds like out of scope?
ZTylerDurden717
Would you mind testing Time Crisis 2 on PCSX2 and see if you can reproduce the issue with this emulator?  I can calibrate perfectly but after that calibration screen I can't hit the edges of the screen (like there's an invisible wall) and the aiming is off like this:
« Last Edit: November 22, 2023, 09:28:08 am by ZTylerDurden717 »
karoloydi
I found another software, but every time I would use that separate software I would have to turn off lichtnarre and disable vjoy.
It's too many steps to just play one game.
karoloydi
Mine is slightly off on top. It goes about 95%. Left right and down is fine.
Fusselkroete
  • sup dudes?
ok maybe in future i find the time to add support for this.
ZTylerDurden717
I made a better video.  You don't have this issue on the sides AFTER calibration screen?
EDIT: Non-issue.  Widescreen patch was on and caused the alignment issue.
« Last Edit: November 22, 2023, 09:50:44 am by ZTylerDurden717 »
karoloydi
No, it works fine for me.
ZTylerDurden717
Works now for me too.
I believe it's a known issue with pcsx2, but if you figure out accurate 2 player split-screen time crisis 2 let us know.
karoloydi
Sometiems I have to turn off and on Lichtnarre a couple of times until it picks up my controllers.
Or sometimes it picks up the first controller and have to turn off and on to pick up the second.
Does anyone else have this?
ZTylerDurden717
Only if Dolphin emu is open while synchronizing LK to wiimotes, I may randomly have something similar.  I usually solve this by not having Dolphin open during the process.
karoloydi
Can you play Dolphin with lichtnarre?
I haven't tried it yet.
It should be more accurate with 4 LEDs.
Fusselkroete
  • sup dudes?
connection problems mostly appears on low battery.
karoloydi
Has anyone managed to get sega clay challenge to work?
I keep getting wrong rom size error.
Edit: I downloaded the latest 0.261 version of mame and it works.
« Last Edit: December 14, 2023, 12:51:31 pm by karoloydi »
karoloydi
I noticed that Sinden light Gun has a 16:9 to 4:3 switch.
That would be very useful to implement for Lichtnarre, and I don't think it would be too hard.
Maybe do a long press shortcut as well? Like we have at the moment for switching between mouse and vjoy?
That would be pretty cool I think.
Fusselkroete
  • sup dudes?
That will not happen. Sinden has no IR offsets/game offsets. It works a little differently here (https://geekonarium.de/en/what-is-ir-offset-and-why-do-i-need-it/). But! There will be profiles for games so that this is then automatically reconfigured when you switch to another gaming/working-process(emulators or something). Also manual switching is possible. Alot of todos already in the queue for LK. Currently you can also just copy and paste the whole installation folder from LK and then configure it for a new game.
« Last Edit: December 28, 2023, 09:20:27 pm by Fusselkroete »
karoloydi
That sounds good to me!
karoloydi
Woohoo!
I managed to get ps3 move lighgun games to work.
I have played Time Crisis Razing Storm and Time Crisis 4 so far. They play great.
I'm downloading some more to try.
It's 1 player only, cause it works with mouse plugin.
If anyone is interested in a tutorial, please let me know.
karoloydi
Another useful feature would be to be able to map the mouse buttons to whichever wiimote button you want. Most of the times the reload button is button A and it's hard to reach. it would be better ot be able to map it to button Z. Also to have a middle mouse button, that would be useful. Some games use the middle button for grenade.
« Last Edit: January 01, 2024, 06:05:36 am by karoloydi »
Fusselkroete
  • sup dudes?
Yes, this is already planned :)
It will be called somehow like this: Tracker to Connector Plugin Assignment System
Tracker Plugins can publish all kind of types. Axis, Buttons, Gyros, 3D positions etc.
This can be assigned to Connector plugin inputs. this hopefully should look like blender shader editor in future. Also Modifiers would be cool to assign inbetween :D.
Coding is pain and slow. so im not 100% sure if this feature will come like this. We will see. :-) But this would be the optimal solution.
Atm i try to publish this: https://drive.google.com/file/d/1Hr5rhfJXKckCDkUgpZxucUXRTshW1757/view?usp=drive_link
« Last Edit: January 02, 2024, 01:42:37 am by Fusselkroete »
karoloydi
Wow,
I can't wait to try it. :D
smallgamer
  • Last login:April 14, 2024, 11:19:32 pm
Been trying out this software recently and its truly something incredible! Unfortunately I've run into an issue. I was able to pair my wiimote to my computer via BT, and am able to have it recognized in Lichtknarre. I have successfully used the Wii controller in the past through software like Wiitar thing or on Dolphin using the sensor bar so I know there is not an issue in detecting the bluetooth pairing. Once paired to Lichtnarre, I am able to do the calibration and then use the wiimote as a mouse on my desktop. However, as soon as I actually launch a game, regardless of the emulator I am launching it with, the Wiimote is no longer detected by Lichtknarre but is still connected to my PC via bluetooth. I have seen others mention that sometimes having Dolphin open can cause a fight between the programs on who detects it but I have turned off any pairing of a real wiimote to Dolphin and Dolphin has never been opened throughout my testing of Lichtknarre. Any reason why this might be happening?
  • Last login:Yesterday at 01:18:51 pm
    • GroovyGameGear.com
This probably isn't all that helpful, but once you have reached that point, anything which happens after that is not specifically related to Lichtknarre.   Something on the system is interrupting the relationship between the controller and the LK software, be it a third party utility which might be waiting in the background to launch with whatever app you are starting, or the app itself.  Basically, anything which hooks controllers to read them directly, even if it is not specifically geared toward BT devices, could interfere with LK's communications.
You stated that you have used other similar drivers/apps on the system prior, so my question is how much of the code from those is continuing to linger on the system, possibly even after an uninstall?  By their nature, some of these kinds of drivers use code which digs deep into the lower rings of the operating system, like at the kernal level, and might be difficult or even impossible to remove without a special piece of software specifically designed for that task, which would need to be provided by the developer.
Or, it might just be a silly configuration error for whichever application might be causing the issue :)  It's hard to know, but if fiddling with app configs yields no success, it's likely going to be something much more difficult to figure out, given the other software you had running previously on the system.
smallgamer
Very interesting! I  thought it was strange that it worked perfectly fine until actually launching a game using an emulator regardless of which one it was. I wonder if it could be something like a frontend software such as Launchbox causing the issue. I will have to do some testing because it seems like the trigger is simply launching a game even through standalone emulators. Has anyone had experience using Lichtknarre and Launchbox?
