Author Topic: Lichtknarre: Unmodified Wii remote as a sight accurate Lightgun using 2/4 LEDs  (Read 290827 times)
firedance
  • Last login:Today at 01:57:32 am
Was making some edits when you posted, hope its useful as i'm in a rush  :-[
The PCSX2 one is very similar, might try and do that later :)
Fusselkroete
  • Last login:January 13, 2026, 11:49:27 am
  • sup dudes?
No hury dude :D Take your time. Make your edits and ping me :D
firedance
Think that's about right :)
I use Launchbox/Bigbox to unzip Playstation roms which is handy as Duckstation doesn't like zipped files.
firedance
A rough guide to setup pcsx2 (i used pcsx2-v2.3.39) for the Lichtknarre software :)
Like i mentioned a few posts back this and Duckstation are very similar so read carefully.
Download and install pcsx2 to the location of choice (mine is - G:/Launcbox/Emulators/Playstation 2 LIGHTGUN, before running it create a blank text file called portable.ini and place that in the root folder of pcsx2, what this does is make it portable and any files that pcsx2 creates will be in the same folder and not in Documents, makes it much easy to move about AND in my case I've created 2 installs of pcsx2, one just for Lightgun games and one for normal controller ones, for me it just makes it quicker and easier than trying to mess about getting all the controllers to work together, Oh Don't forgot the Bios files ;)
Run pcsx2 so it creates the files it needs, exit then run Lichtknarre with the Vigem Plugin, connect your wiimote as you normally would, leave that running then start pcsx2 ->
pcsx2 -> settings -> Controllers
In the new window change the settings to the ones in the attached pictures (Don't know how to get the attachments inline in this forum  :-[)
Like i said in a previous post i had trouble setting up the relative aiming with the Wiimote so manually edited the PCSX2.ini file which is found in the inis folder which is located in the root folder of pcsx2, make sure pcsx2 is shutdown then open the file, scroll down to [USB1] and change the relative positions to these, your DInput might be a different number to mine so change accordingly.
guncon2_RelativeLeft = DInput-1/-Axis0
guncon2_RelativeRight = DInput-1/+Axis0
guncon2_RelativeDown = DInput-1/+Axis1
guncon2_RelativeUp = DInput-1/-Axis1
Save the file then restart pcsx2, of course your controllers maybe in a different order but once set up correctly you should now be able to play Lightgun games with your Wiimote and Lichtknarre  ;D
You can change how you like your buttons, i've since added the Time Crisis proof of concept pedal i made months ago, plugged it into a test joystick with a zero delay encoder (shows as DInput-2: Generic usb stick) it works a treat :)
**edit i added the same cursors from Duckstation, setup is the same, just didn't take a screenshot**
Hope the above makes some kinda sense :)
Fusselkroete
  • sup dudes?
Nice Tutorials (i had no time to test)... and now go for RetroArch :cheers:
« Last Edit: December 06, 2024, 01:45:01 pm by Fusselkroete »
firedance
Will leave Retroarch for a while :o  instead i got model 3 working by using the awesome guide from the Launchbox forum - https://forums.launchbox-app.com/files/file/3857-sega-model-3-supermodel-git-everything-pre-configured-inc-controls-for-pc-controller-mouse-light-guns-test-menus-configured-free-play-all-games-in-english-2-player-mouse-support-audio-adjusted-layout-imagesthe-whole-9-yards/
Great respect to Warped Polygon for all the man hours they put into sorting it all out  :notworthy:  :notworthy:  :notworthy:
Used the DInput config then all i did was swap round the trigger and A for the Wiimote on the gun games then changed the Gas and Brake as they were set to the right stick on my Xbox 360 controller.
The Wiimote does come up as gun/player 2 but i can live with that for now, should be easy enough to swap round :)
Fusselkroete
  • sup dudes?
LK is work in Progress.
Sooner or later there will be configurationprofiles and other stuff :)
BTW BigBen WiiGun Lens Adapter:  https://www.thingiverse.com/thing:6856444
« Last Edit: December 06, 2024, 04:03:33 pm by Fusselkroete »
firedance
forgot to add, Model3 crosshair isn't that smooth when using the wiimote as it is in other emulators, guess it's just how the emulator registers the joystick as a light gun, have yet to switch to mouse API but assume it would be smoother.
Fusselkroete
  • sup dudes?
More interesting Stuff:
3D Lightgun print: https://makerworld.com/de/models/867328
A fork of pcsx2 for lightguns: https://github.com/nixxou/pcsx2
RandyT
    • GroovyGameGear.com
I often see these 3D printed items incorporating a lens and have to wonder if the designers took the time to disassemble their Wiimote (and re-assemble it) to find the exact center of the camera lens.  If they didn't, it's probably wrong and it will likely affect sight accuracy without very good software correction.  Hint:  it's not centered in the window :)
« Last Edit: December 10, 2024, 12:47:12 pm by RandyT »
Fusselkroete
  • sup dudes?
hi dude :D
i tryed several wii motes with this guncase. seems to work the same for every wiimote.
https://forum.arcadecontrols.com/index.php/topic,169046.0.html
Maybe your right. Just my experiences.
if it doesn't sit quite right in front of the camera, then every IR light tends to be scaled/distorted in one direction. It should therefore be possible to compensate for this with adjust x and adjust y in the software. Perhaps the larger the screen, the more significant the effect?
« Last Edit: December 10, 2024, 01:48:21 pm by Fusselkroete »
RandyT
hi dude :D
Back at ya! :)
If the lens is off the center axis, it can introduce parallax in the image.  Obviously, the further off axis and the more powerful the magnification, the worse the effect will be.  I have a hunch that a larger screen, which places the references into the higher distortion areas of these inexpensive lenses, will exacerbate the problem, but I haven't thought about that part specifically.  Ideally, the best case scenario would be to have all elements of the optical system (that's what is being created) exactly on axis with one another.
A simple offset in the X and/or Y will probably not be enough to compensate for parallax, as it distorts the entire image and that distortion will change the position of the reference LEDs, depending on where the camera is pointed within those boundaries.
Fusselkroete
  • sup dudes?
Ah yes i remember. We had this topic a while ago and all kind of solution to map the magnification offcenter.
A method with different magnification rings around the center which can be moved offset from the center. A raster mapping method etc. Still have this stuff in my backhead.
Different lences needs different methods. i bet the wii remote camera has itself some kind of magnification.
:D thanks again for the brainstorming.
One simple magnification method is already implemented:
https://docs.google.com/document/d/117MScFdwIa9OmT3HLUYOvgB_TzmynupzVe_1zai4rFo/edit?usp=sharing << "How does it work with the lenses?"
i should also add center offset and offer more options in future! the centeroffset needs to be intutive to figure out for the user in some ways. still thinking about this.
« Last Edit: December 10, 2024, 03:44:47 pm by Fusselkroete »
RandyT
While I think that it could be corrected with some advanced algorithms, I also think that a poorly designed optical system should not be the concern of the software.  This type of thing isn't the same as sort of getting the lens in front of a cell phone camera to take a picture.  If it's off a little one way or the other, or slightly distorted, you'll still get a half-decent snapshot.
And yes, the camera needs some kind of lens of it's own to focus the incoming light onto the sensors.  Distance between lenses is also important.  These cell camera lenses expect to be pretty close to a camera lens, as is typical with cell phones.  There is probably 2 to 3 (or more) times that distance when used on a Wiimote.  This is likely to affect focus and could also result in vignetting or trying to use parts of the lens which are not ideal.
I just wanted to underscore the importance for people to do their due-diligence before throwing more lenses into the optical path.  It might technically work, but there might also be some unintended side effects which affect overall accuracy.  With optics, things need to be correct to give the system the best chance to work as intended.
firedance
Just trying a test batch file to shut down then restart Lichtknarre after a emulator, found a basic file and edited it to match the file locations -
taskkill /IM Lichtknarre.exe /F
Pause
start/wait "Dolphin" /B  "G:\LaunchBox\Emulators\Dolphin\Dolphin.exe" %1
Pause
start "Lichtknarre" /B "C:\Program Files\Lichtknarre\Lichtknarre.exe"
Pause
exit
when its run I get this -
C:\Users\Retro-pc\Desktop>taskkill /IM Lichtknarre.exe /F
ERROR: The process "Lichtknarre.exe" with PID 8752 could not be terminated.
Reason: Access is denied.
Tried it with other programs and it works as it should, any ideas how to easily solve as when i googled a solution my brain hurt   :o
Fusselkroete
  • sup dudes?
And yes, the camera needs some kind of lens of it's own to focus the incoming light onto the sensors.  Distance between lenses is also important.  These cell camera lenses expect to be pretty close to a camera lens, as is typical with cell phones.  There is probably 2 to 3 (or more) times that distance when used on a Wiimote.  This is likely to affect focus and could also result in vignetting or trying to use parts of the lens which are not ideal.  Maybe the ppl should build a realy big 90° wooden angle. xD
I see two problems (For now we ignore lens rotation). Bad lens centerpoint and bend camera. Both can be compensated to a degree. But to find an intuitive method for the user is hard, since the camera only can see IRs.
For the first problem, you could place the IR LEDs in each corner of the screen and place the Wii 90° in front of the screen to see the difference between the top and bottom distance. But the user has to be 100% accurate. Aim from the center of the screen and 90° perfectly to the screen. Poor user experience imop. For the other problem, maybe you could use the same approach. Maybe people need to build a big 90° angle out of wood or 3D print one :D The 3D print could be mountable. Maybe you don't need the screen at all and make a 3D print where the Wii can be mounted exactly. Hey that could be the solution...
Sorry for my bad paint skills :( Maybe i design this and offer this tool. The Tool also could help to detect if your camera bending is too extrem to fix by software.
Btw the one who made this 3D Print (https://makerworld.com/en/models/867328
) like to join the forum, but registration is disabled. Who i have to ask for registration? He gave me his emailadress.
« Last Edit: December 11, 2024, 07:35:20 am by Fusselkroete »
Fusselkroete
  • sup dudes?
Pause
Pause
Pause
exit
Your Batch script do not run as administrator. Look for tools which helps you to evaluate the batch script as administrator.
RandyT
Lol.  I never stated that the people who design these didn't do everything they should, only that I wonder if they did.  The reason is that, intuitively, one would be tempted to only center the lens on the aperture of the window and proceed.  In this case, that is not ideal.  But it is enough to take the controller apart to see where the camera lens center actually is (a micrometer is fine for doing this) and use whatever references they want in their design to find the appropriate center location for the optic.  Horizontal center is is probably a safe bet just using the window, but not vertical.
As a side note, a 3rd party camera module could be in an entirely different place.  That window is huge compared to the camera aperture, so there's lots of room for it to be in different place and still work just fine in stock form ;)
firedance
Pause
Pause
Pause
exit
Ran it has a admin, it closes Lichtknarre then loads Dolphin but when i exit Dolphin Lichtknarre doesn't reload,any ideas how to fix it ?
I even reinstalled Lichtknarre to a different drive and still the same result :o
Fusselkroete
  • sup dudes?
What do you mean by not reloading?
firedance
From the batch file, when you exit Dolphin it should then load Lichtknarre, which it doesn't  :-[
Tried the same batch file with fatmatch.exe (first program i picked from my utils folder) and that reloads, that file doesn't need the batch file to run as admin though.
On my retro-pc i disabled UAC so don't think its that.
Fusselkroete
  • sup dudes?
Yes because Pause says you have to press a button to continue the batch script? Im not an batch script expert. would be nice if you post the solution if you figured it out. :)
firedance
Should have said, tried it without the pauses and it still doesn't load Lichtknarre again after Dolphin, will do some research when i get the chance :)
firedance
Made a AHK file instead of a batch file and used this code -
Process, Close, Lichtknarre.exe
runwait "G:\LaunchBox\Emulators\Dolphin\Dolphin.exe"
run "G:\LaunchBox\0-UTILS\Lichtknarre\Lichtknarre.exe - Shortcut.lnk"
Had to make a shortcut so it would load after Dolphin closes, works now :)
Hope it comes in handy for someone.
Fusselkroete
  • sup dudes?
Amazing  :cheers:
Now retroarch :)
zenaro147
  • Last login:January 07, 2025, 06:52:49 pm
Hi 😀
I actually edit the design to center with the wiimote camera, since after disassemble my control, I notice that the camera is not centered with the black window. Do you think it's better to center with the window instead the camera?
firedance
Amazing  :cheers:
Now retroarch :)
I did look at a few cores for NES in Retroarch but they seem to be hard coded to use the mouse only for the lightgun/zapper :(
Fusselkroete
  • sup dudes?
Hi a user with the name of Away8777 of the Geekonarium Discord server made a tutorial for model3. See pdf in attachment.
Little hint from Luftwaffles side is: his vjoy's were player 1 and player 3 because he had some other virtual device installed on windows taking 2nd player.
I hope this will help ppl to net get confused.
Update: he rewrote the Sega Supermodel 3 vjoy tutorial. I attached this as 2.0 version.
« Last Edit: January 21, 2025, 02:43:06 am by Fusselkroete »
Fusselkroete
  • sup dudes?
Hi my friends,
Away8777 does another tutorial for us. Its for flycast + vjoy2. Big thanks to him.
ZTylerDurden717
  • Last login:January 18, 2026, 10:33:39 am
Hello,
Attaching tutorial for setting up Lichtknarre with PCSX2 two player using Vjoy.  I highly recommend using user nixxou's pcsx2 fork build because it fixes split-screen time crisis 2 and 3.
https://github.com/nixxou/pcsx2/releases
« Last Edit: January 21, 2025, 05:34:17 pm by ZTylerDurden717 »
firedance
Used the Dolphin bar with beta firmware, this Wii gun and a mobile phone lens like this one -
https://www.ebay.co.uk/itm/175136735064?var=474327492963
Cut off most the spring clip to just leave the ring, taped it on temporarily to test, worked a treat so super glued it to the end, can get much closer now to my Neoncade bartop with it's 19" screen, have got a 4 led harness coming from aliexpress so hopefully should get even closer or i may use that on my TV instead :)
Fusselkroete
  • sup dudes?
Cool and does it work? :)
firedance
The 4 point led harness finally arrived, went for black LED's as i may dissemble my Neoncade when the weather is much warmer and put them behind the plexi, the top one will be a little tight for space tho, at the moment i've just taped them to the outside of the bartop with taped offcuts of the same plexi  covering the LEDs for testing purposes, they work a treat after i manually adjusted the offsets in Lichtknarre :)
https://www.aliexpress.com/item/1005004523162882.html?spm=a2g0o.productlist.main.1.4b7291rE91rEyB&algo_pvid=369c0a09-613f-4b46-aac9-dc329d8c891a&algo_exp_id=369c0a09-613f-4b46-aac9-dc329d8c891a-0&pdp_ext_f=%7B%22order%22%3A%2283%22%2C%22eval%22%3A%221%22%7D&pdp_npi=4%40dis%21GBP%2114.59%2114.59%21%21%2117.51%2117.51%21%40211b615317392848912891572e0cec%2112000033430236398%21sea%21UK%210%21ABX&curPageLogUid=fPEG94JcbuXy&utparam-url=scene%3Asearch%7Cquery_from%3A
ZTylerDurden717
I have the same IR harness and they work great!  Glad it's working for you too.  If you have a quick clip of you blasting stuff on your cab that'd be cool to see  :cheers:
Fusselkroete
  • sup dudes?
Hi my friends,
Away8777 does another tutorial for us. Its for vJoy+TeknoParrot. Big thanks to him.
firedance
It was a cold frosty morning when I decided to hack/bodge the LED harness into the bezel of my Neoncade, could have done it much neater but you can't see it too much behind the  tinted plexi and if you squint  ;D
Had some black silicon that's used for outside repairs to fix the LEDs in place, once dry it's pretty hard so they aren't going anywhere, quick test and they work perfectly, will need to to sort out the offsets in the software but that's easy enough :)
(sorry about the blurred pictures)
ZTylerDurden717
Nice work!
mickael28
  • Last login:March 31, 2025, 05:56:29 pm
Do you guys know if the wireless version on that link could work for a distance of 3 meters from a ~120" projector? It'll be a distance/screen size ratio pretty much of 1:1
I read it was recommended 3W IR LEDs, so not sure if that wireless version would be enough.
Having read some of the DIY version you guys have done, I don't have a clue how to do that myself, hence looking for a version already done for a large screen
Fusselkroete
  • sup dudes?
Hi, it depends on how much solar radiation you have or how many other light sources there are that have IR radiation. Also beware relections from your IR source. The distance depends on which IR tracker you use. I assume the 4 LED tracker with your planned purchase. It is not always easy to say whether it will work at 3m, as there is no exact formula for this. As a backup plan, you can also make a 3d print that uses a lens.
