Author Topic: Aliens extermination guns  (Read 9919 times)
arcadeguncab
  • Last login:October 09, 2024, 12:34:22 pm
« on: September 27, 2022, 12:34:23 pm »
Hello, i have some problems with my 2 guns.
I have make a full reinstall with windows 10, ( my old installation with windows7 was not compatible mamehooker)
The problem :
With my old installation, the two guns runs correctly, and calibration in the service menu full complete.
In my new installation with win10, impossible to configure the second gun, in the service menu, only one gun can calibrate. When Aliens extermination launch, i have two gun detected  :banghead:
Anyone has the solution ?
mrbee
  • Last login:November 15, 2025, 03:47:22 pm
Re: Aliens extermination guns
« Reply #1 on: April 24, 2025, 12:48:44 pm »
Im having this exact problem, hoping someone will see this old post and response and offer some advice!
I have just built a custom case inside a military ammo box for the guns. all works great except for the issue you are having - guns detected fine in windows, calibrate nicely, game boots and says 2 guns detected, when calibrating then the left gun trigger buttons, and position etc no response at all!
mrbee
« Reply #2 on: April 29, 2025, 07:54:58 am »
Well, I've installed it to a fresh windows 7 system, ive bought a brand new powered usb hub, ive tried them in two separate usb ports on the pc without the hub....
Game boots, recognises that there are 2 guns.. only one gun will calibrate!!!
I guess the only way is to get it working via teknoparrot
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
« Reply #3 on: May 20, 2025, 05:19:16 pm »
Hi guys,
tested today with 2 guns and Win10 and works perfect. In test menu, press "1" for gun1 calbration and press "2" for gun2 calibration
  • Last login:January 10, 2026, 01:02:58 pm
« Reply #4 on: May 29, 2025, 09:53:19 pm »
Yeah I finally got my second gun in and it seems to calibrate just fine.   Like he said, be sure to press two player start to calibrate the second one.
« Reply #5 on: May 29, 2025, 09:55:03 pm »
barring that I believe the ABH.adj file contains the calibration so I suppose you could copy that from someone else's install.
