Author Topic: Vertical cab monitor issue  (Read 2885 times)
mikehaggar
  • Last login:September 23, 2022, 04:16:24 pm
« on: September 20, 2022, 04:20:42 pm »
Hi all, got a vertical cab the other day but the guy must have put the monitor in upside down as when I set mame to vertical in the ini file its upside down. What setting do I change in the uni to flip it the right way round? Thanks.
abispac
  • Last login:Today at 12:26:35 am
Re: Vertical cab monitor issue
« Reply #1 on: September 20, 2022, 06:24:55 pm »
on mame.ini its either
rotate left   1
or
rotate right  1
buttersoft
  • Last login:Yesterday at 06:23:34 pm
  • Is running at 15kHz
« Reply #2 on: September 20, 2022, 08:27:19 pm »
[T]he guy must have put the monitor in upside down...
There kinda isn't such a thing as upside down when it comes to arcade tubes. You flip them to hide screen burn, and then flip the yoke connectors on the PCB or use the dip switches there.
Calamity
  • Moderator
  • Last login:Yesterday at 06:06:14 pm
  • Quote me with care
« Reply #3 on: September 21, 2022, 06:00:37 am »
Depending on what side the CRT is mounted, either -autoror or -autorol in mame.ini will do the trick.
Steps to create a log:
mikehaggar
« Reply #4 on: September 21, 2022, 03:31:13 pm »
Thanks for help guys. Putting a - before the autorols didnt do anything and adding a left or right to rotate 1 didnt do anything either. Any other suggestions?
makya
  • Last login:August 05, 2025, 09:31:18 am
« Reply #5 on: September 21, 2022, 03:49:48 pm »
Hi you should trying replacing one of those 0 with a 1.
rotate                   0
ror                       0
rol                       0
autoror                0
autorol                0
good luck !
mikehaggar
« Reply #6 on: September 22, 2022, 06:03:31 pm »
Yeah tried changing all the rotate options there and nothing happened.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 05:37:39 am
« Reply #7 on: September 22, 2022, 06:29:00 pm »
cut-and-paste. Modify as you wish:
# CORE ROTATION OPTIONS
rotate                    1
ror                       1
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
mikehaggar
« Reply #8 on: September 22, 2022, 07:42:02 pm »
Yea Ive tried rotate 1 and the ones below with various 1s but nothing happens. Stays just upside down vertical
Zebidee
  • Trade Count: (+9)
« Reply #9 on: September 22, 2022, 08:52:03 pm »
Three ifs:
If you are changing those settings but nothing happening, then maybe you are editing the wrong mame.ini
If all else fails: start GM into the default GUI. you can navigate to "Configure Options/Advanced Options" and change rotation there. Don't forget to "Save Configuration" before exiting out.
If curious, you can then check your mame.ini "CORE ROTATION OPTIONS" and see what was changed.
buttersoft
« Reply #10 on: September 22, 2022, 10:07:08 pm »
Ah yes, that's a good one to check. In the same dir as the mame executable, first i would rename the ini folder so nothing is interfering, then make the changes to the mame.ini. Then try them,  and if they fail, see if the changes are still saved, or have reverted.
Zebidee
  • Trade Count: (+9)
« Reply #11 on: September 23, 2022, 02:14:33 am »
Butters raises a good point. If there are any other .ini files being loaded, like a "vertical.ini" in your INI folder, they will override the mame.ini settings.
mikehaggar
« Reply #12 on: September 23, 2022, 07:34:44 am »
Yea it was the vertical written in the core options for orientation, it needed to be rotate_l then it worked. Thanks for your help all!
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   generic_15
orientation               rotate_l
