Author Topic: Anyone in Springfield, MO ...  (Read 2444 times)
Pepper3
  • Last login:December 20, 2022, 12:13:46 am
« on: September 08, 2022, 12:48:02 am »
...that I could hire to help me build a MAME cab?
lilshawn
  • Last login:December 04, 2025, 08:10:20 pm
Re: Anyone in Springfield, MO ...
« Reply #1 on: September 08, 2022, 10:08:33 am »
how much you looking to pay?
perhaps your money would be best spent buying an already done machine.
  • Last login:Today at 12:09:57 pm
« Reply #2 on: September 08, 2022, 10:33:43 am »
I wish I was closer. I would be glad to help.
You are like an 8 hour drive away.
Pepper3
« Reply #3 on: September 08, 2022, 01:04:52 pm »
Way too far. Thanks anyway.
  • Last login:Today at 10:30:54 am
« Reply #4 on: September 08, 2022, 03:16:41 pm »
Why are you asking for help?
Woodworking:  There are companies that produce IKEA-style "flat pack" kits or you might be able to find a suitable non-working and/or partlially-stripped arcade cabinet in the greater Springfield area.
Wiring:  There's a slight learning curve, but it should work out fine with a little practice, taking things one step at a time, and using velcro or twist-ties to keep the wires neat as you build the harness.  You might also consider buying a replacement JAMMA harness, cutting off the edge connector, stripping the wires, and connecting them to your IPac or other encoder.
Software/configuration:  There are lots of guides for installing and configuring MAME.  It is easier to find a suitable ROMset first then download the corresponding version of MAME/GroovyMAME.
- For example, if you find a MAME v0.241 ROMset, download v0.241 of MAME/GroovyMAME.  If a ROMset doesn't clearly state which version it is, find one that does.
rsimp7255
  • Last login:February 10, 2023, 12:33:38 pm
« Reply #5 on: October 18, 2022, 04:19:31 pm »
417arcades.com
To Alcohol! The cause of... and solution to... all of life's problems.
 - Homer J. Simpson
