Author Topic: Winipac won't map keys properly  (Read 1207 times)
junkcollector8
  • Last login:September 19, 2022, 05:33:09 pm
« on: September 05, 2022, 05:48:45 pm »
Hopefully I'll get this kinda close. I've had a MAME that I bought back in 2013. Worked well up until the other day. I've done no update, changed NOTHING. Its not even connected to a network. After booting Millipede in Hyperspin, the fire button just stopped working. I've tried re-mapping the button but I'm not getting any success. I probably won't way it correctly but I can press the keyboard and see the button "working" on the screen in Winpac. I can even fire using the keyboard. However, I can't get the button to map so that I can fire from the previously assigned button. I tried dis and re-enabling the driver in Control Panel and disconnecting and reconnecting the USB to see if that would work. I have a video here on youtube that visually shows the challenge in case I'm not writing about it properly.
Rataplan626
  • Last login:May 02, 2024, 01:42:27 pm
Re: Winipac won't map keys properly
« Reply #1 on: September 27, 2022, 12:44:16 pm »
Couldn't fully watch the video. But if you start notepad or anything you can type some text in, do your buttons do anything?
