Author Topic: Question about Individual Rom CFG files...  (Read 2995 times)
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« on: March 01, 2004, 09:29:38 am »
So, using Mamewah, I started Robotron and set up the player 2 Joy to be the firing joystick.
Well I get out, and back in and I have to reset those settings.  Should this not save in an individual cfg file, or is there something else I should do?
cdbrown
  • Bowowow
Re:Question about Individual Rom CFG files...
« Reply #1 on: March 01, 2004, 08:52:20 pm »
Did you check that a robotron.cfg file was created in mame\cfg folder?
Is the cfg folder set in mame.ini like
cfg_directory           cfg
Does it only happen to Robotron or other games as well?
Setabs
  • Last login:March 07, 2015, 03:03:23 pm
  • 100% MAME compatible.
    • Another Useless Webpage
« Reply #2 on: March 01, 2004, 09:23:14 pm »
make sure you are not pausing the gaming when you use  mame to edit the button config's.  I did this in MK and it took me about six trys before I figured out you can't have mame paused when changing the controls.  And also when you upgrade mame and the roms later on it will reset the buttons.
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
« Reply #3 on: March 02, 2004, 12:53:52 am »
This happend to me too... I dont know why either, so i edited a config file myself for the controls, but some of it was slightly off so i tried using mame again and it works now ???
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #4 on: March 02, 2004, 02:25:50 am »
You guys need to read the directions for the ctrlr files in Mame.  These will totally solve all your problems regarding this.
  • Last login:Today at 01:32:52 pm
« Reply #5 on: March 02, 2004, 03:33:41 am »
yeah cfg files are lame and unreliable.  Ctrlr files always work well because they are external and can't be altered accidentally by mame.
JamesS
« Reply #6 on: March 02, 2004, 08:47:31 am »
Thanks everyone.  I will look into the CTRLR files.
Thanks again.
JRoz
  • Last login:February 14, 2024, 07:33:43 am
Re: Question about Individual Rom CFG files...
« Reply #7 on: March 21, 2011, 08:58:14 pm »
Sorry to bring this back from the dead but i'm having issues with my video settings.  I'm running Mala with Mame and running it on a cocktail cabinet.  I'm able to go into Video Settings and change the screen to Cocktail, but the setting automatically removes itself every 3rd time.  So for example I say to cocktail, return to game and play.  I exit out normally and go back into the game and its still in cocktail.  When I exit out normally again, the game boots and the video setting resets back to the standard horizontal setting.  Anyone know what I can do?  I copied and pasted the cocktail command in the CFG file and hit save, and everytime it shows it in there correctly, when I go in the third time and its reset, the CFG file also deletes the code.  I don't get it!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #8 on: March 23, 2011, 08:22:29 pm »
I suggest asking at MAMEWorld. It might be a bug.
-Banned-
