Author Topic: Help needed with Arcadevga card and WG9200  (Read 1539 times)
Squizzy2
  • Last login:December 18, 2022, 01:39:29 am
« on: June 18, 2022, 06:52:27 am »
 Hello
 First time poster.
I have had my arcade mame cabinet fro many years and finally the HDD decided to no longer work.
 The old pc I feel is now longer useful to use again with a new HDD as it has the original ArcadeVGA APG card and next thing to go wrong will be t he MB.
 So I was looking around for an ArcadeVGA pci 5000 card, but these are no longer available.  :(
So what do I do now to get full use with the WG9200 monitor  and mame? from memory the Monitor will do 15/25/31KHZ
 So it was good for SF and MK etc
Zebidee
  • Trade Count: (+9)
  • Last login:February 07, 2026, 01:57:20 am
Re: Help needed with Arcadevga card and WG9200
« Reply #1 on: June 18, 2022, 01:15:35 pm »
Get an older ATI/AMD/Radeon video card and install CRT_emudriver + Groovymame. Or Groovyarcade, at least to get you going with your new system.
Check out the stickied threads on the Groovymame branch of this forum :D
If you decide to replace the HDD in old system, suggest you get an SSD instead.
