Author Topic: The Anyway Joystick-8/4/4Angle/2Vert/2Horizontal-leaf switch  (Read 3531 times)
slinghit
  • Last login:October 14, 2024, 12:25:26 pm
  • I like building controls
I have a new, very limited run, product. The Anyway Joystick. Internally it uses a Groovy Game Gear Dominux8 joystick which has the rubber encapsulated steel centering grommet and arcade-quality leaf switches.
I have created a set up that will allow this joystick to select 8way/4way/4way-45 degree/2way horizontal and 2way vertical - mechanically from above panel. You get the feel of the original WICO like joystick but can select the correct configuration for the game. I have been using one for years, on my machine, that uses multiple original PCBs. I just didn't like the feel of the spring type joysticks nor did I want several joysticks on my cabinet to match all the different requirements.
The kit will come with a jig to cut the round hole and shelf needed to install.
I have made three, and can make more if needed, but I can only make, maybe, one every two weeks.
Please ask any questions.
The unit with installation template is $265.00 plus shipping.
I am the person that has been making Front Line Rotary Switches.
Thank again,
« Last Edit: May 17, 2022, 01:17:43 pm by slinghit »
