Author Topic: HyperSpin/RocketLauncher hiding keypresses from MAME emulator  (Read 1825 times)
JV
  • Last login:May 17, 2022, 04:41:50 pm
Hi
I have a cab thats running hyperspin with a miniIPAC & a USB keyboard and everything was working just fine.
I decided to upgrade to Mame 243 this week. I updated mame successfully and everything was working okay.
I started updating the keyboard configurations in mame & HyperSpin to get the controls just right
Unfortunately, after I was done I noticed a problem that now when I launch any emulator (SNES/MAME/etc) from hyperspin - keys presses are sporadically not registering within the emulator that's running.
When I either
1. Use Windows Task Manager to kill the Hyperspin process and tab back into the emulator - all keypresses register
2. Disconnect the USB Keyboard - all keypresses register
I think I have mis-configured something in HyperSpin/RocketLauncher that is causing a conflict with the USB Keyboard & miniIPAC that effectively 'hides' keypresses from the emulators. I remember changing multiple cfg/ini files while upgrading to MAME 0.243 but I cant find the problem.
Would anybody have ideas on how I can debug/fix this issue?
JV
Re: HyperSpin/RocketLauncher hiding keypresses from MAME emulator
« Reply #1 on: May 17, 2022, 04:41:41 pm »
So I found a solution to my problem, just putting it here in case anybody else has the same issue.
My solution was in RocketLauncherUI on Global -> Main Settings tab -> Mark 'Suspend Frontend' as true.
This fixed my issue across all my emulators.
