Author Topic: Upgraded from 0.239 to 0.242 and low res VERTICAL games are stretched on horizo  (Read 3028 times)
eewoke
  • Last login:April 14, 2023, 05:18:23 pm
Hi,
I use GM on a Hantarex polostar 25, windows 10 and an ATI R7 360 videocard using super resolutions. All was running like a charm. But feom GM version 0.239 I updated to version 0.242 and suddenly the vertical games on my horizontal monitor with low resolutions are stretched(like Donkey Kong, Pac-Man). I rolled back and found out this is the case from version 0.240 and onwards. I use vertical.ini for monitor 15_25_31 in case that matters.
What might cause the problem? Any idea? Did Mame.ini change?
Any help is appreciated as I could not solve it myself.
« Last Edit: April 16, 2022, 02:54:29 am by eewoke »
psakhis
  • Last login:September 24, 2024, 11:54:25 am
Hi,
Test applying intoverscan. In my case, i set intoverscan 1 on .ini file, but you can pass this an argument.
eewoke
Hi,
Thanks for your help. Unfortunately this is not the solution. I am still struggling. Very strange that the latest 3 GM versions have this problem on my system.
« Last Edit: April 17, 2022, 10:37:12 am by eewoke »
Calamity
  • Moderator
  • Last login:Today at 03:49:47 pm
  • Quote me with care
eewoke,
Please get me a log of a game that shows the problem. This must be caused but the new scaling method in recent versions.
Steps to create a log:
eewoke
eewoke,
Thanks Calamity! Will do this Weekend as I am traveling now for work.
eewoke
eewoke,
Hi Calamity,
Please review attached file. I hope you can find the cause and solution. Thanks!
Calamity
  • Moderator
Thanks! Confirmed, will work on a fix.
eewoke
Great! I wish you a lot of success!
