Author Topic: upgrade bartop to bigger one?  (Read 2733 times)
slybunda
  • Last login:October 15, 2024, 05:41:42 pm
« on: March 22, 2022, 04:40:44 am »
hey all, after the success of the bartop fixer upper thats working great now, wondering if i can build a bigger one to use all the space i have on the table/cupboard.
Full width of the table is 80cm. current bartop is 49cm in width leaving 31cm extra width not used.
Depth of the table is 50cm but bartop overhangs out the back being 55.5cm deep.
Height of table is about 73.5cm.
current bartop has a 19inch screen.
only issue i have is that all new screens are wise screens so dont know if a 24 inch wide is gonna end up working out same as old 19 inch square making it kind of pointless. i havent found square screens that are bigger than 19 incher too.
id like new bartop to be higher up like a full size cab would be so puts less stress on my back when standing over it as i currently do. also lot of sun glare in the day time due to the angle of the screen. so if new bartop has more height then the screen can sit more vertical and not get washed out by the sunlight. bartop is in the conservatory which has a transparent roof so lots of light getting in during the day.
how should i start going about this? iv attached some pics to give you guys an idea of space etc.
ericball
  • Last login:March 13, 2025, 11:01:47 am
Re: upgrade bartop to bigger one?
« Reply #1 on: March 22, 2022, 02:48:05 pm »
A 16:9 screen with a diagonal more than 24" will be taller than a 19" 4:3 screen and you should be able to squeeze anything smaller than 36" into the 80cm width footprint.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
slybunda
« Reply #2 on: March 23, 2022, 05:22:50 am »
Thanks for the reply. I was just about to get confused since 80cm is around 32inches but then remembered thats a diagonal size lol. 32inch tv is fairly cheapo. Could also use the speakers that come in the tv so that saves hassle on a separate audio solution
  • Last login:Today at 11:05:02 am
« Reply #3 on: March 23, 2022, 05:48:19 am »
Pick one measurement system and stick with it please.
slybunda
« Reply #4 on: March 23, 2022, 06:36:58 am »
ok cool.
would i be better off just getting a ready made solution like this one:
https://www.ebay.co.uk/itm/184331582462
they say they can alter it some. maybe increase its width?
  • Last login:Yesterday at 09:19:57 pm
« Reply #5 on: March 23, 2022, 10:33:38 am »
I went through several iterations on my bartop. I built the table to hold 2 bartops, then I made it smaller to hold 1 bartop. Eventually I just built the bartop to a cabaret.
http://forum.arcadecontrols.com/index.php/topic,158517
classicjoe72
  • Last login:October 11, 2022, 11:23:40 am
  • I want to build a Fix-It-Felix Jr.!
« Reply #6 on: April 27, 2022, 08:33:00 am »
Why not build a nice pedestal? The cabinet can sit inside of it like an Arcade1Up cab but much taller to bring it to the height you need.
