Author Topic: Hole Dimentions  (Read 1565 times)
waters_jim
  • Last login:March 16, 2022, 05:42:45 pm
Hole Dimentions
« on: March 15, 2022, 02:26:05 pm »
For a 3 inch Harp Trackball what size hole should be cut. Also for the Joystick and Harp buttons?
Thanks,
  • Last login:March 05, 2026, 12:10:15 pm
Re: Hole Dimentions
« Reply #1 on: March 15, 2022, 04:37:48 pm »
Do you have a mounting plate?  I'm not sure how you would do it without one unless you plan on removing A LOT of material underneath.  If you have the mounting plate, this is all you need: http://forum.arcadecontrols.com/index.php/topic,119081.0.html
I am pretty sure the hole you want is 3" exactly - that's the outside diameter of the lip around the trackball.
Buttons are typically 1-1/8" for buttons and joysticks although I've been cutting my joystick holes 1" lately for... reasons?  I don't know.
Whatever you do, test everything on scrap before committing to the real thing.
