Author Topic: Help with mame and slikstik controls  (Read 1869 times)
Imnewidkwhattodo
  • Last login:August 18, 2022, 07:47:16 pm
« on: March 06, 2022, 12:12:10 pm »
Not sure if i posted this in the right spot im new please bare with me. Im new to this.
So heres my dilemma. I got a free slikstik cabinet from a customer at work that was disassembled. Ive seen it working in the past. I hooked it up as I thought it should be and kept getting a keyboard error, i order a keyboard and got it yo actually load the OS and mame. Ive followed the slikstik user manual but it doesn’t actually show how it hooks up to a pc. With 1 configuration i had the spinner and trackball working both as a horizontal mouse.
Im not sure exactly how it plugs into the pc correctly tho. I have cables for “trackball, spinner, unlabeled usb, pc, pass through. It has a 4 port usb and 2 PS/2 to usb plugs. I cannot find any actual photos online of one showing how it supposed to be hooked up.
« Last Edit: March 11, 2022, 09:49:09 am by Imnewidkwhattodo »
jimj
  • Last login:August 27, 2024, 06:39:31 pm
Re: Help with mame and slikstik controls
« Reply #1 on: March 12, 2022, 05:57:23 pm »
From the last post in http://forum.arcadecontrols.com/index.php?topic=97561.0 you can download "slikstik.iso" which is a image of the CD that probalby came with that cabinet.  In its "SlikStik Utilities" folder is a "manual.pdf" from 15FEB2004.
http://www.retroblast.com/reviews/slikstikclassic.html has a link to http://www.retroblast.com/files/SlikStikUserGuide.pdf which is a 29OCT2004 version of the manual.
A 2006 version of the manual is available here:
   https://www.kutek.net/mame_roms_pinball/mame32_config_files/slikstik_controller_manual.pdf
but it doesn't have as much info and its text isn't searchable.
Hopefully one or more of those manuals can  help.
Generic PS2 to USB adapters may not work (correctly) with the IPAC4 inside your control pannel.
I have the SlikStik Classic Controller which is the 2 player version, but you should have the same connections.  You should have three connections to make:
   1. IPAC:      USB (with an Ultimarc cable) or PS2 keyboard port
   2. Trackball:   USB PS2 mouse port
   3. Spinner:      USB port
I wouldn't use a USB hub, one more thing to break/cause problems.
Note if you're using Windows 10, you must have your IPAC connected via USB (with the correct cable from Ultimarc) to program it.  If you're not going to program it, then you can use its PS2 connection.
One last thing to note, you don't need to install any drivers or software (WinIPAC) to use your control panel.  You only need WinIPAC if you want to change its programming.
