Author Topic: RGB bubble top JLF joystick  (Read 1593 times)
rackoon
  • Last login:May 14, 2024, 01:12:10 pm
  • I EAT PENCILS!
« on: March 02, 2022, 05:01:31 pm »
I would like to make or buy a JLF RGB clear bubble top joystick. The only options I see at all the regular shops are with the white tops but I hate how they look when not on.
I know where to get a hollow stick in 6mm and 10mm but the for 10mm I only can find white tops and for the 6mm I would need a very small RGB led and that has turned out to be hard to do :banghead:
Im I the only one out here who are interested in this? :dunno
Do I need to get 10mm sticks and have the bubble tops made?
I think I may be able to use hollow ball tops with 6mm sticks :dizzy:
Anyone out there who has ued any of these ideas or how did you get it done?
They treated me like an animal and that's what I became.
rackoon
  • I EAT PENCILS!
Re: RGB bubble top JLF joystick
« Reply #1 on: March 03, 2022, 05:39:21 pm »
OK I have ordered some 6mm JLF long hollow sticks from some shop in Europe (only place that has stock)
I also orderd some Kori hollow clear mesh ball tops. My hope is that I can stuff the led in the ball top then thred the wires down the shaft before I screw them together
Am I correct in thinking that I dont need resistors for each color when using an Ultimate Ipac? :dunno It should help with the wiring
I also think that I need common diode RGB led's right :dunno
Now I just need to find a way to get all four wires though the shaft. Anyone know if thats possible? I got to solder leads to the led and heat shrink them. I am hoping that if I stagger the connections they may all fit.
So no one has tried any of this  :dizzy:
