Author Topic: Wiring - monitor and power supply  (Read 1386 times)
rdharles
  • Last login:February 09, 2022, 11:23:14 pm
« on: February 03, 2022, 04:12:58 pm »
Hi,
Recently purchased a 60-1 cabinet custom built.  It contains a flat screen monitor, 60-1 board, jamma harness, computer power supply.
The power is wired so that when I flip the power switch in the back, everything turns on/off.  I suppose that's pretty common but I don't like it.
I want the power to the power supply on constantly and the switch to turn off only the monitor.
My question is, how do I rewire the switch so only the monitor turns off when I flip the switch in the back?
This is how the switch is currently wired: image 1 & 2
This is my switch: image 3 & 4
...AND HERE IS MY QUESTION, will this rewiring work to keep constant power to the power supply and the switch will turn on/off the monitor? (image 5)
Thanks for any help/advice you can give!!
RD
« Last Edit: February 03, 2022, 05:33:32 pm by rdharles »
  • Last login:Today at 03:22:22 pm
Re: Wiring - monitor and power supply
« Reply #1 on: February 03, 2022, 05:01:22 pm »
Not quite.  You got ground right, but you've got the power supply and monitor labels switched.
To do what you describe, you want the power supply on the A and C tabs of the switch (before the switch = always on) and you want the monitor on the B and D tabs of the switch. (after the switch = switch turns it on and off)
rdharles
« Reply #2 on: February 03, 2022, 05:32:01 pm »
OK, that makes sense now (that it's opposite), my "lamp" is only on when I turn the cabinet on.
Really appreciate you taking the time to post!
Cheers!
RD
