Author Topic: Help programming ipac4  (Read 1335 times)
Sarlo
  • Last login:January 23, 2022, 01:04:42 pm
« on: January 23, 2022, 01:04:42 pm »
I'm using the ctrl alt p method to remap the keys to my ipac 4 (old model) from my slikstik.  Everything is working fine except my player 1 joystick won't take up/down/left/right.  When i mpa other keys it accepts it and says "done"...when I map the joystick keys it says "one".  I have pasted the notepad file below if that helps.
 *** i-pac interactive programming and test mode ***
    t for button test mode
    l to list current config
    r to reset eeprom to mame defaults
    e to save and exit
    a to abort
    or press switch you want to program
    coin 3  = 7
   4 right = -
    coin 4  = 8
   4 left  =
    start 3 = 9    3   * shift *
    4 up    = *
   start 4 = 0
    4 down  = +
   3 right = l
    4 sw 1  = del
   3 left  = j
    3 up   = h
   3 down  = k
    4 sw 2  =
   3 sw 1  =
    4 sw 3  = '
    3 sw 2  = 5
    4 sw 4 =
    3 sw 3  = m
    4 sw 5  =
    3 sw 4  =
    4 sw 6  = ]
    3 sw 5  = o
   4 sw 7 = \
    3 sw 6  = b
   4 sw 8  = p
    3 sw 7  = t
   3 sw 8  = p
    coin 1  = 3
    2 right = g
    coin 2  = 4
    2 left  = d
    start 1 = 1      1   * shift *
    2 up    = r
    start 2 = 2
    2 down  = f
    1 right =        tab
    2 sw 1  = a
    1 left  =        entr
    1 up    =        `
    1 down  =        f12
    2 sw 2  = s
    1 sw 1  = lctl
    2 sw 3  = q
    1 sw 2  = lalt
    2 sw 4  = w
    1 sw 3  = spce
    2 sw 5  = e
    1 sw 4  = lshf
    2 sw 6  = [
    1 sw 5  = z
    2 sw 7  = ]
    1 sw 6  = x
    2 sw 8  = p      esc
    1 sw 7  = c
    1 sw 8  = p      esc
done
    press next switch or e to exit
    exiting...codes saved.
    e to save and exit
    a to abort
    1 up       press keyboard key to set..   one
    1 right    press keyboard key to set..   one
     1 left     press keyboard key to set..   one
    press next switch or e to exit     1 down     press keyboard key to set..   one
