Author Topic: konami winding heat AT/MT option defaults to MT unless the button is held  (Read 3581 times)
martymart
  • Last login:January 09, 2022, 04:36:00 pm
I am working on a konami winding heat. Every time you start a game the transmission changes to manual. As this game has the ability to switch throughout the game it keeps defaulting to manual unless you hold the botton down.
I have found 2 different manuals with 2 different dip switch settings for AT/MT (DIP switch 2). Can anyone confirm if the dip switch is the cause of this issue and if I should change the setting for this.
« Last Edit: January 09, 2022, 04:36:27 pm by martymart »
