Author Topic: Question: Painting My Cabinet  (Read 2372 times)
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« on: February 27, 2004, 08:02:07 am »
Hello all,
I'm almost through with my first MAME project and I have one last question.
What type of black paint should I use?
The cabinet is a former Centipede cabinet that was converted to Big Event Golf.  The sides are now laminated solid green (yuck!).  Should I just spray paint the sides or use a roller?  Use flat, gloss, semi-gloss, eggshell?
Anyone willing to post some examples of their finished project?
Thanks,
Todd
Re:Question: Painting My Cabinet
« Reply #1 on: February 27, 2004, 08:55:47 am »
I would say most people use a roller.  Personally I am going to roll on some 'satin' finish paint (kindof matt with a smooth finish, probably the same as what you call 'eggshell').
Some people use gloss, but I would probably stay away from matt/flat since it doesn't tend to wear very well.
Edit: I have limited experience with this, and my cabinet is not finished so probably a good idea to wait for other peoples opinions!  :)
« Last Edit: February 27, 2004, 08:56:47 am by Minwah »
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #2 on: February 27, 2004, 09:51:19 am »
I used a high quality semi-gloss applied with a medium nap roller.   Looks great!
ps - I also primed it first!
« Last Edit: February 27, 2004, 09:52:23 am by DeathMonk »
Now with cup beer holders!
bioart
  • Last login:November 28, 2006, 11:38:14 pm
    • The ArtCade
« Reply #3 on: February 27, 2004, 10:40:32 am »
I'm thinking of painting mine.  I'm building it out of 5/8" particle board.  I would assume primming would be a good idea...
I figure if the paint doesn't look that good, I can always attach formica panels to the main areas later. (and/or side-art once I decide on a logo)
Art
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #4 on: February 27, 2004, 02:34:34 pm »
I am in the same stage of the build as you. Ready to paint the cab. Over the last few weeks I have been experimenting with the control (mobile) panel. Here are my results:
1. I used Primer as the first coat. Make sure the Primer is all purpose and can be applied to MDF. The wrong primer will ruin your CAB! (pour some water on a scrap piece and wait overnight to see what I mean.
2. I used Foam brushes (both roller and brush style). Very smooth finish with no lines. I Just threw them away when done after each coat (I am using melamine), live in the country on a septic system, and cannot use solvents to clean up brushes...
3. I tried a latex flat black. I hated it. I found it to mark and scratched very easily. Clean up is easy through
« Last Edit: February 27, 2004, 02:38:27 pm by jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #5 on: February 27, 2004, 03:18:33 pm »
If you are using particle board as opposed to MDF, I would suggest not painting it. It won't look good. MDF takes paint well, but particle board is very rough and will have an ugly texture unless you apply lots and lots of filler.
Go with laminate instead of paint.
« Last Edit: February 27, 2004, 03:19:04 pm by FractalWalk »
saint ganked my avatar.
Stingray
« Reply #6 on: March 01, 2004, 10:34:34 am »
I painted mine with automotive enamel. First it got two coats of primer, then another two coats of gloss black with a healthy dose of hardener tossed in. The paint was applied with an air powered paint sprayer.
-S
mahuti
« Reply #7 on: March 01, 2004, 11:06:25 am »
1. Buy some kind of spray ENAMEL primer. Some people use rustoleum, or other automotive brands. Apply very light coats about 1-2 feet away. Enamel takes a long time to dry. So give it the recommended time to dry (the time on the can). Spray enamel primer gives the base a very smooth thick coat. You will see glaring mistakes (if you've made any) Now is the time to fix them. Apply 2-3 coats of primer. Do not sand between or after coats
2. Buy a smooth or very smooth foam roller (smooth nap works OK but leaves more texture) Use black Enamel paint. Again, automotive paint works fine. Don't use a spray can for the finish. ABSOLUTELY do NOT use latex. Latex dissolves in water, it tears, melts, scratches easier than enamel. Apply one full coat of the black enamel. Allow 24-48 hours to dry in a normal room temperature environment for the paint to cure correctly between coats. You may want to do a light hand sanding between coats. Apply up to 3 coats. If you apply too many coats, it will be more prone to chipping. After you do the last coat allow a few days to cure, then do a light buffing if you want, or better yet, just leave well enough alone, and be finished.
http://homepage.mac.com/mahuti/altcab/PhotoAlbum37.html
