Author Topic: Outrun 2 Teknoparrot - .bat file to boot game?  (Read 5762 times)
esoteric_rt
  • Last login:July 16, 2024, 08:04:33 pm
« on: November 07, 2021, 04:40:42 pm »
I'm in the process of converting an Initial D to Outrun 2
I need the PC to boot Outrun 2 SPDX in Teknoparrot when windows starts
What would the text in a .bat file need to be?
buttersoft
  • Last login:Today at 06:56:07 pm
  • Is running at 15kHz
Re: Outrun 2 Teknoparrot - .bat file to boot game?
« Reply #1 on: November 08, 2021, 05:36:11 am »
Mine seems to contain 3 lines to actually run the game. You may not even need the first two, in which case remove them or "rem" them out. But i run a few programs alongside the game and want to make sure it actually runs.
cd\
cd C:\games\TeknoParrotUi
start C:\games\TeknoParrotUi\TeknoParrotUi.exe --profile=OR2SPDLX.xml
There's a directory under teknoparrot called profiles, i think it might be. just use the profile you want in the line above to run the game you want.
esoteric_rt
« Reply #2 on: November 08, 2021, 02:39:52 pm »
Thanks for that, I'll give it a try
esoteric_rt
« Reply #3 on: November 09, 2021, 03:27:26 pm »
It worked great, thanks
I only needed the last line (and to amend for my file locations):
Then you just place the .bat file in the windows startup folder
