Author Topic: Connecting my PC's VGA output to my CRT TV's component input  (Read 7190 times)
cloudeleven
  • Last login:July 26, 2023, 07:19:06 am
« on: October 07, 2021, 03:13:20 am »
Hi, I'm pretty new to this, but I've been reading a lot here trying to figure out what to do. I eventually want to dive into GroovyMAME, but not right now...baby steps  :lol. I acquired a CRT TV with component input today (an LG DU-27FB32C that accepts a 480i signal). At the moment I'm just trying to connect my PC's VGA output port to the TV's component input to get regular MAMEUI to display on the TV. Is this cable (and a male-male component cable) all I need for that?
https://www.amazon.com/StarTech-com-Cable-Adapter-Component-HD15CPNTMF/dp/B00213KFHW/ref=sr_1_16?dchild=1&keywords=vga+to+component+transcoder&qid=1633588545&sr=8-16
The reviews say your VGA pins need to output component for that cable to work, and I think mine does (see attached pic of the VGA port, it has 15 pins). My PC is a Dell Inspiron 3670 using Windows 10 and the VGA port is the motherboard onboard graphics (Intel UHD Graphics 630, I don't have a dedicated graphics card).
Or do I need something that will convert VGA to component? I think this would be the item: https://www.ebay.com/itm/174166352619?hash=item288d1fa2eb:g:T~8AAOSwz1Rc-BCM. But that's a little expensive at $50...maybe I should go the PC HDMI to TV component converter route? Those are $20 on Amazon, and this one says it supports 480i for component video: https://www.amazon.com/Portta-Converter-Component-Support-Extractor/dp/B00A8FIQXA/ref=sr_1_4?dchild=1&keywords=portta%2Bhdmi%2Bto%2Bcomponent&qid=1633595995&sr=8-4&th=1
Thanks.
« Last Edit: October 07, 2021, 05:00:44 am by cloudeleven »
bobbyb13
Re: Connecting my PC's VGA output to my CRT TV's component input
« Reply #1 on: October 07, 2021, 03:57:23 am »
Make your life easy and results grand with one of Zebidee's boards!
http://forum.arcadecontrols.com/index.php?topic=164245.0
buttersoft
  • Last login:Yesterday at 06:29:58 pm
  • Is running at 15kHz
« Reply #2 on: October 07, 2021, 10:29:18 pm »
DO NOT buy Zebidee's Greenantz converter - at least, not yet. It's an excellent unit, but it converts 15kHz VGA or RGBS to 15kHz YPbPr. You have a few things to sort out first.
Your CRT accepts 15kHz (240p/480i) over component. Your PC (on windows) is only going to output 31kHz (480p) VGA at it's lowest. To get 15kHz out from that PC you either need to:
1. get a cheap AMD GPU (say, a 5450 - assuming a prebuilt Dell is going to let you use crt_emudriver anyway) and a converter like Zebidee's or the one you linked to as expensive (it's not, for what's out there). This will give you best-quality low res video with good colours. It involves learning about crt_emudriver and modelines and setting the right options in MAME.
2. or you buy that second, cheaper HDMI-to-YPbPr converter you linked to. That will work, but will turn your desktop (at, say 1080p) into 480i. Picture quality will suffer, but you'll have to try it to find out how much. You might find it acceptable. It's certainly as easy to get running as that, and your cheapest option as well. You could even do this first, and upgrade things later if you decide to.
https://www.aussiearcade.com/topic/76809-a-guide-to-connecting-your-windows-pc-to-an-sd-crt-tv-pvm-or-arcade-monitor/
That cable you linked to first of all is not normally for a PC. There are some older, obscure GPU's that can use it, but it's really meant for a device that can input/output component video over a VGA DB15HD plug. Traditionally that meant a projector, but now you could probably use it for MiSTer as well, i think.
« Last Edit: October 08, 2021, 07:11:31 am by buttersoft »
bobbyb13
« Reply #3 on: October 12, 2021, 01:32:17 pm »
Buttersoft is right of course, I was a bit overzealous and assuming too much.
If that PC has a PCI- e slot buy a graphics card on Calamity's list as buttersoft sugggests.
My method to take ALL the potential confusion out of flashing it with CRTemudriver and use GroovyMame to great effect is to:
1. Get a graphics card that has a DVI-D  AND VGA output, like this one.
https://www.ebay.com/itm/255168379252?_trksid=p2334524.m570.l5999&_trkparms=gh1g%3DI255168379252.N36.S2.typeWATCH_ITEM_ENDING_SOON.R4.TR4
2. Use a DVI-D PC monitor as your primary during setup.
This allows you to leave that primary one plugged in throughout the whole process and always have a monitor that you can see what is going on.
If followed to the letter, Calamity's walkthrough and this card/monitor combo truly makes set up a breeze.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 06:33:02 am
« Reply #4 on: October 12, 2021, 05:54:54 pm »
Butters is right of course, and the guide he linked to is very comprehensive. However, I suggest you get the transcoder first, and not just because I keen for another sale. Assuming your only CRT display is the component TV, you will need the transcoder to see successful results from the PC at 15khz.
GreenAntz is just plug n play and uses standard cables - you simply setup your PC to output RGB 15khz over VGA normally, like for an arcade monitor or RGB TV (using CRT_emudriver, GroovyArcade or whatever). With the transcoder plugged into PC and standard component CRT it should just work right away. This will give you best results and allow you to get original and crispy arcade/console retrogaming modes like 240p.
With Windows 7+, for easy CRT_EMU setup I suggest you look for an ATI/Radeon video card that is HD6XXX+, the HD5XXX cards work too but can be a little trickier to setup.
I don't recommend the HDMI-component converter you linked - it will scale, squash and squeeze your original PC resolution into the selected format (480i looks like the only resolution offered that would work on a standard definition CRT), which will not only wrong but also interlaced (so it will look flickery, not crispy). In addition, that converter seems to be only for HDTV resolutions like 480p+. Component video colour conversion is handled a little differently for HDTV vs SDTV. I know it says 480i there too, which is technically SDTV, but I'm not quite sure I believe it handles the colour conversion properly for SDTV.
Avoid the VGA-component breakout cable, as Butters says it will only work with specifically designed equipment that outputs component video over VGA pins. Nice that it works with the Mister :D, I got something similar for mine recently, but it is a trap for new players.
