Poll
What are the best colors for a cab?
Total Members Voted: 0
Author Topic: What are the best colors for a cab?  (Read 2953 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: February 26, 2004, 03:49:18 pm »
Just a friendly poll to see what colors y'all like on your cabs!
If you don't see an option you like, write-ins are acceptable...
« Last Edit: February 26, 2004, 04:51:09 pm by 1UP »
My other job...
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re:What are the best colors for a cab?
« Reply #1 on: February 26, 2004, 03:57:06 pm »
Why, Pac-Man yellow of course!
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
« Reply #2 on: February 26, 2004, 04:11:23 pm »
Glossy-black with a flat-black for contrast  ::)
Thank you Paul Jr.... we are all now a little dumber.
Is wood-stain a color?
Mucal invader, is there no end to your oozing?!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: February 26, 2004, 04:19:08 pm »
If you like woodgrain formica...
My other job...
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #4 on: February 26, 2004, 04:24:36 pm »
But...  But... But... What about my original orange Reactor cab?  You saying it's so ugly it doesn't even deserve a spot on the poll?    :'(
If no one feeds the trolls, we're just going to keep eating your goats.
TheTick
  • I.P. Daley
« Reply #5 on: February 26, 2004, 04:28:39 pm »
Good point... where's the "other" option. What about multi-color eye sores? Those seem to be popular as well  ;D
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: February 26, 2004, 04:30:46 pm »
Woodgrain, marble (ugh) whatever, if there's a color that's not listed, write it in.  We only get 8 slots in the poll-maker folks... :P
My other job...
MinerAl
  • Last login:January 27, 2025, 07:02:58 pm
  • duck
« Reply #7 on: February 26, 2004, 04:43:58 pm »
I can think of excellent examples of most of them, and horrible of all of them.  Black with a well chosen set of color graphics is probably the best solution, but then there's pacman yellow...
Lilwolf
« Reply #8 on: February 26, 2004, 04:56:43 pm »
btw... your having your cabs milled right?
Is there a minimum cab count on the cuts?  IE, starting with 3 4x8s do you end up with the wood for 1 cabinet?  Or do you have them all mixed around (so to cut the top panels you do 5 on one sheet?).
If you have it designed one cab per set of wood... you SHOULD be able to do custom orders without much trouble.
Lilwolf
« Reply #9 on: February 26, 2004, 05:03:25 pm »
I change my vote to the full sideart that has the images that change when you look at them and move (whats the name of that... the textured look at 3 angles).
One for each control panel...
That... might... cost as much as the rest of the cab...
but would really really be cool!
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #10 on: February 26, 2004, 05:07:03 pm »
What, no Centipede (off-) white? Okay, okay, without sideart the white surface would look dull.  :D
1UP
  • Token Junkie
    • 1UPArcade
« Reply #11 on: February 26, 2004, 05:12:17 pm »
I was thinking of that.  The two side panels will have to be on separate sheets, there's no way around that.  If you laminate both of those, that means you have room for some other major panels to be cut from those sheets.  The third sheet could be mainly the unseen panels, and left black.
Adding laminate will add expense, so the standard would probably be black melamine, and colored laminate can be added at an extra charge.  Anyway, this is for the other thread...  ;)
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #12 on: February 26, 2004, 05:17:11 pm »
Or just wait until e-paper is available in large sizes...you could have the appropriate sideart be displayed on the entire side panel depending on what game you're playing!  You could have changeable panel art too... -drool-
My other job...
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« Reply #13 on: February 26, 2004, 05:44:17 pm »
 :o :o  Can I have mine in TIE DYE? Groooovy, man.   :o :o
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
mvaughn
  • Last login:December 05, 2007, 11:25:55 pm
    • NukeSilo.com
« Reply #14 on: February 26, 2004, 06:58:47 pm »
I've been toying with the idea of using a glowing green color on black... I'm trying to get a radioactive effect.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #15 on: February 26, 2004, 08:58:41 pm »
what about a Hypercolor cab!!!  you breathe on it and it turns a different color....ah yes, the early 90's or late 80's...i cant remember 8)
cdbrown
  • Bowowow
« Reply #16 on: February 26, 2004, 09:11:13 pm »
I'm thinking a deep blue - with a few coats of clear laquer
paigeoliver
  • Awesome face!
« Reply #17 on: February 27, 2004, 12:33:48 am »
You forgot white. White is the 3rd most common cabinet color (after black and woodgrain). I have at least 4 white cabinets (Do! Run Run, Kangaroo, Turbo, Sprint 2).
crashwg
« Reply #18 on: February 27, 2004, 12:40:56 am »
 Oh man, those color changing shirts were the shiznit... :P
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #19 on: February 27, 2004, 12:50:28 am »
blue
1UP
  • Token Junkie
    • 1UPArcade
« Reply #20 on: February 27, 2004, 02:36:21 am »
I thought I had put white...ok, it's there now.  I'd refuse to make a marble cab anyway!  :P
My other job...
pcdoctor
  • Last login:July 21, 2014, 06:44:02 am
  • I'm a Girl Gamer!
« Reply #21 on: February 27, 2004, 02:47:29 am »
I think it depends what the cabinet is for.
Ex. fighting games, retro games, etc.
G@M3FR3@K
  • Last login:December 31, 2015, 12:20:28 am
« Reply #22 on: February 27, 2004, 04:53:03 am »
What about Light Blue (A.K.A. Donkey Kong Blue)?  ???
« Last Edit: February 27, 2004, 05:05:54 am by G@M3FR3@K »
Magnet_Eye
  • Feel the heat?
« Reply #23 on: February 27, 2004, 08:25:14 am »
Oh, how about Sea Foam Green?
Pastels are cool!  :o
G@M3FR3@K
« Reply #24 on: February 27, 2004, 08:41:10 am »
And don't forget "Joust Brown"  ;)
xcalibur
  • Last login:August 22, 2012, 11:15:35 pm
  • You sold my dead bird to a blind kid?
    • Dallas Starcade
« Reply #25 on: February 27, 2004, 09:21:34 am »
OCC refrence = Greatness! :)
Thanks,
