Author Topic: using panel clamps to mount my cp  (Read 1071 times)
yup
  • Last login:February 26, 2004, 02:31:15 pm
« on: February 26, 2004, 03:02:56 pm »
i must be completely retarded...i got these off an old cab, and i'm trying to use them to mount my cp, but i have absolutely no idea how they work. can someone help out a engineer-ically challenged person?
Xiaou2
  • Last login:Today at 09:40:42 am
  • NOM NOM NOM
Re:using panel clamps to mount my cp
« Reply #1 on: February 26, 2004, 04:44:22 pm »
 Well, first just mount the metal holders (hook part) onto the panel.
  Next, put the panel in place, while holding the clamp part right under where the holder is.   You want to mount the clamps slightly below the holders - so that when you close the clamp, it will clamp really tightly.
 If you look at the panel clamps,  you will see that they use a spring in them.  This spring travels about 3 to 4 mm  when you have locked it into place...  so thats why you want to make sure that the clamps are mounted low enough to make the springs compress a bit.
