Author Topic: Modified Happ S360  (Read 3120 times)
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Modified Happ S360
« on: February 26, 2004, 09:08:10 am »
Been playing around with the idea of air cooling a Happ Stick for some time.Too many times have i been defeated by the big boss because my hands got too sweaty during the heat of battle and i slipped at that critical moment...
Well no more!!!
 Took some dimensions off my happ P360-optical and used that as a starting place. I will post blueprints you can provide to any local machine shop for you to bring your happ stick and have it modified to operate like this. Or perhaps depending on interest i will offer the service myself.
I couldnt get my host to take all my images..more to come..
Enjoying the fruits of technological obsolescence one game at a time...
Harakiri
  • Last login:February 13, 2014, 05:02:37 am
  • Invisible member status
Re:Modified Happ S360
« Reply #1 on: February 26, 2004, 09:24:46 pm »
Looks great! Send it to Happ to see what they think! Congrats!  ;D
Generic Eric
« Reply #2 on: February 26, 2004, 10:05:32 pm »
That is cool
I am looking forward to the blue prints.
DYNAGOD
« Reply #3 on: February 27, 2004, 07:01:48 am »
I was a bit concerned about the input tubes influence on the feel of the stick but there is absolutely none to speak of. I made a preproduction mockup and the stiff springs in the p360's make it so that you dont even feel the thing. Tubing is available in all kinds of materials and you can get it with almost no natural stiffness making its almost mechanically invisible, even in the dead zone where theres no spring resistance.
It looks mean like an angry 300 lb gorilla.. ;D
DYNAGOD
« Reply #4 on: February 27, 2004, 12:14:15 pm »
theyll probobly sue me  :o ;D
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #5 on: February 27, 2004, 01:42:02 pm »
He, he cool idea (pun intended)  8)   That's the same size handle shaft as on the Wico's isn't it?
You use a compressor to get the air to move through the tube or does the motion of the stick somehow create airflow?
DYNAGOD
« Reply #6 on: February 27, 2004, 03:11:44 pm »
to answer your first question im uncertain what similarities if any the happ and Wico's share. i would imagine most sticks are nearly identical and any differences are likely just cosmetic,though I might have to pick one up for  comparison.that is unless someone here has an old wico thats passed its usefull life that they wouldnt mind parting with to broaden this projects scope. ;D
Airflow will be supplied via a smal electric pump. something like you see in fish tank bubblers, only quieter. This will be routed to a micro-pneumatic 90deg swivel fitting tapped and loktite'd in place at the base of the happ stick. the pump will be boxed and acoustically insulated to prevent any unwelcome acoustic radiation and the outside of the box will then be covered in Adhesive backed PORON for vibration dampening.
heres a pic of the stick itself untapped and without the pneumatic fitting
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #7 on: February 27, 2004, 03:27:31 pm »
Sorry, I should have checked myself. I just bought a set of Happs 360 metal SlikStik handles to go in my Wico bases. I just wasn't sure if it was the 360 model, but indeed it is. In fact the handles are very particular per type of joystick. Though, apparently Wico used the same handle on several of their sticks. The 360 which was originally a Wico product.
Are you gonna sell this type of joystick handle or just a plan on how to build them? I can imagine getting the shaft machined, but where would one get a bat grip like that? Or is the plan to drill a hole through the shaft and puncture the grip with a lot of holes?
DYNAGOD
« Reply #8 on: March 01, 2004, 09:18:52 am »
sorry for the late response, i have not internet access at home at the moment and i can only log in at work..
contrary to what i had initially hoped, this item would have to be an assembly. i had thought that perhaps I could do this in one piece and in turn modify an existing joystick, but what im finding is that is that its much simpler to make it out of two pieces from scratch. modifiying an existing stick IS possible but would require some unpleasant parting lines in the conical handle. which imho is not acceptable  :-[
The conical handle would start off as a piece of round stock.it would then be turned on a lathe having the internal diameters drilled, bored and finished. it would then go to mill having a series of 10 flats about twice the diameter of the drill bit placed on its diameter over the lenght of the part. this will give the drill a nice starting point without walking. it would then be drilled and returned to the lathe department to put the profile on it. then that top section would be mated and permanently bonded with the much simpler lower shaft section.
all in all alot of work for something so really insignifigant, and most likely not cheap.. but its totally for fun!  once i build the protoype and get a handle on the total machining time ill have a better idea of what this little gem will cost.
depending on if i could do it without loosing my shirt i would offer the service through the machine shop i work at, but most likely i would simply provied the blueprints and bill of materials here for anyone to have done themselves.
ive taken enough from the emulation scene.. i cant code in C or crack hardware protection so im useless there. but I do good cad/cam work  ;).. and I would like to be able to give something back to the community which has given me so much joy..
this and a couple of other ideas i have in the works which i will be posting here soon are my chance to do that.
« Last Edit: March 01, 2004, 09:21:16 am by DYNAGOD »
