Author Topic: Golden Tee Home No Video Output  (Read 2904 times)
nguerra
  • Last login:February 27, 2025, 11:55:00 am
« on: July 12, 2021, 05:17:11 pm »
hi everyone, hope someone can help.  Have been playing Golden Tee home 2020 for about 6+ months now.  Was playing a game yesterday and the picture froze with a stutter in the sound.  Turned the cabinet off and waited 1 min.  Game no longer boots.  No Signal to the HDMI.  Cabinet PC turns on and all fans are running.  I/O board has three lights.  One steady green, one green flashing, and one red flashing.  PC gives off three beeps from the motherboard.  Any suggestions to determine what may be the problem?
Thanks Nick
Nitro0602
  • Last login:July 26, 2025, 11:44:11 am
Re: Golden Tee Home No Video Output
« Reply #1 on: July 13, 2021, 01:16:31 am »
Three beeps that repeat after a pause and occur when you power on your computer indicate a problem with the system memory. Three beeps that play and then stop as the computer starts successfully mean that the BIOS was restored... got that from google.. happened to me one time and I just popped out the ram and put it back in and good to go. Worse case you may have to replace the ram, but that should be an easy fix.
TOMMYGUN
  • Last login:May 20, 2025, 02:45:11 pm
  • When the time comes you will know
« Reply #2 on: July 13, 2021, 04:41:04 am »
if you buy new ram look at Kingston they are the most reliable
nguerra
« Reply #3 on: July 13, 2021, 08:00:05 am »
Thank you for the feedback.  The three beeps only occurs once during the startup.  I will reseat the ram anyway and comeback with findings.
