Author Topic: Hantarex polo 28 verticle collapse after tweaking remote board  (Read 3135 times)
Stevie187
  • Last login:June 30, 2021, 04:02:50 pm
Hi guys,
I Recently begun work to fix this time crisis cabinet I have, I removed the time crisis chassis to check some of the boards. On replacing the chassis I couldn't get the picture to hold at all it was rolliing in both directions that I could see. After threading the remote board through to the front for the cab I managed to get a semi still picture but it wasn't right and would drift off again after a while or if you breathed on the remote board pots. Thinking I had possibly dislodged the connector on the remote board I jostled the connector on the remote board and accidently disengaged it for a second doh! After reconnection the screen is showing verticle collapse with just a bright line across the middle. Any ideas what might have happened and whether the remote board can cause this? Before I start checking the monitor chassis.
Steve
grantspain
Re: Hantarex polo 28 verticle collapse after tweaking remote board
« Reply #1 on: June 29, 2021, 04:10:40 am »
first thing to do is plug the remote directly onto the chassis
Stevie187
« Reply #2 on: June 29, 2021, 08:55:13 am »
Thanks for the help grantspain I appreciate it, sadly with the remote board plugged straight in the same vertical collapse.
grantspain
« Reply #3 on: June 29, 2021, 10:12:56 am »
if you are lucky then its possibly the vertical size pot broken or a bad solder joint
Stevie187
« Reply #4 on: June 29, 2021, 01:25:55 pm »
OK I measured the resistance on the V. Amp pot at the connector and was getting about 60 ohms to about 187 kohms, so that pot seems to be OK although the v. Shift in the centre semms to give about 1.07kohms no matter what position its in which doesn't seem right but would it give the symptoms I'm suffering?
grantspain
« Reply #5 on: June 29, 2021, 06:52:35 pm »
yes that could do it, any issue on vertical line will result in partial or full collapse
Stevie187
« Reply #6 on: June 30, 2021, 11:12:04 am »
Sorry I made a noob mistake and was not measuring resistance on the wiper, the pot checks out. I tested the other resistors and diode and they all seem to be within tolerances too. What do you think is a good thing to test next as the remote board itself seems OK.
Steve
« Last Edit: June 30, 2021, 01:10:56 pm by Stevie187 »
grantspain
« Reply #7 on: June 30, 2021, 03:10:29 pm »
check for bad solder joints next on the chassis, after that you would be looking at testing 25v line to the vertical ic
